civic with gsr swap but no fuel prime?
Old Oct 31, 2005 | 05:03 PM
ej8slim's Avatar
Default civic with gsr swap but won't start?
Just finish my swap, I try to start my car up today but it's seem like there is no fuel going to the engine? I checked the fuse and my wiring already but nothing. I tried to turn the car on but all the interior light turn on and it cranks but won't turn on. Not even the cel light turns on.
Modified by jrepa at 10:42 PM 10/31/2005
Old Nov 1, 2005 | 09:11 PM
TrueZen's Avatar
Default Re: civic with gsr swap but won't start? (jrepa)
My swap did the same thing, just run some discreet switches somewhere.
Old Nov 1, 2005 | 09:31 PM
ej8slim's Avatar
Default Re: civic with gsr swap but won't start? (TrueZen)
what do you mean?
Old Nov 2, 2005 | 10:13 PM
civicyellow's Avatar
it might be you fuel cut relay in your alarm or immobilizer if you have one, if not check your main relay under the dash, if that doesn't work, try wiring up the fuel pump straight to the battery to see if the fuel pump is good
Old Nov 3, 2005 | 02:35 PM
ej8slim's Avatar
I tested the main relay on my brother car but that work. My car doesn't have a immobilizer and it does not have a alarm. What else?
Modified by jrepa at 4:20 PM 11/3/2005
Old Nov 4, 2005 | 09:11 PM
ej8slim's Avatar
Got it to work. It was the green plug that connect to the ecu. Thank for all you help
Circaskaterr
Apr 29, 2025 12:31 PM
ilikehonda
Aug 17, 2010 06:33 AM
90AcuraIntegra04
Jan 6, 2006 05:41 PM
jdm_eg
21
Sep 7, 2004 06:49 AM
WhiteWhiteTeg
Nov 9, 2003 08:29 AM
