Engine shutting off at 1,900rpm?
Old Oct 31, 2005 | 04:25 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Engine shutting off at 1,900rpm?
Car will run fine when it's first started but after it is warmed up it won't go above approx 1,900rpm without immediately shutting off. Once the rpm drops back down close to idle the engine will refire.
It's almost as if the fuel cut point has suddenly been set very low with an even lower engine restart rpm.
Engine is a Turbo B18B with a GM 3 bar map using Uberdata as engine management.
I've tried reflashing the EPROM (however I didn't change any settings) and even swapped ECU's. I also tried swapping distributors with another known working unit.
Any ideas?
WojtekG
Sep 13, 2018 07:15 AM
dh1212
Apr 2, 2016 04:08 AM
mr. goodwrench
Nov 17, 2008 04:35 AM
