what's wrong????
My car wouldn't turn on and it would make a noise like it needed a new starter. So i put one in and it still doesn't want to turn on. It still makes the same noise. We double checked if it was put on right, and it was. What else should be the problem. I'm still learning about cars, so if you can put it in the simplest terms, Please.
I have a '92 Honda Civic Hatchback
Thanks
Thanks
pull the starter back out...
1. check and make sure u put the shim on it if it came with one(the little peice of metal thats in between the starter and the tranny.
2. check the teeth on the flywheel to make sure the teeth on the flywhell are not stripped.
3. for ***** and giggles call and make sure they gave you the right starter, expecialy if u got it at advance, pepboys, or autozone or sumthin
can u explain the noise?
does it go away when its running?
does it start at all?
gobblebox59
Sep 4, 2004 09:05 AM
