would a 99 ex distributor fit on a d16z6
I would say yes.. BUT the connectors will be OBD2 not OBD1.. depends on the engine harness or if you have an adaptor...........
yes it will fit - but the plugs will not line up with obd1 -
you would either need to splice into the dizzy wires, or swap every thing else over to obd2 to match lol
yes it will fit
if you are good with a small screw driver and a needle you can switch the plugs, and as long as you are dealing with the dizzy i wouldint cut and splice you're harness i would try switching the plugs
just make sure u make a pic of where the wires go
nicko360
Mar 3, 2007 07:52 PM
slksol
May 11, 2003 06:44 PM
