Homemade DIY Turbo Fitting
Old Oct 31, 2005 | 12:21 PM
SleeperDC2_ZzZ's Avatar
Default Homemade DIY Turbo Fitting
Well I couldn't afford turbo adapter fitting so a buddy of mine ended up fabricating one. He used a piece of metal plate and then welded the plug on the top with a hole tapped in it already. Then he used a drill to make the holes for the screws.
I used a dremel to cut the sides and sanded the edges. Then the product was done.
Enjoy:
Old Oct 31, 2005 | 12:29 PM
cyb3rjak's Avatar
Default Re: Homemade DIY Turbo Fitting (SleeperEH2_ZzZ)
Old Oct 31, 2005 | 12:51 PM
macDelli's Avatar
Default Re: Homemade DIY Turbo Fitting (cyb3rjak)
crafty
Old Oct 31, 2005 | 01:01 PM
Dan-Dillinger's Avatar
Default Re: Homemade DIY Turbo Fitting (macDelli)
does the job
Old Oct 31, 2005 | 01:05 PM
TheIntegraGuy's Avatar
Default Re: Homemade DIY Turbo Fitting (hondacivicEK)
whatever works.
Old Oct 31, 2005 | 01:12 PM
cd5_2NR's Avatar
Default Re: Homemade DIY Turbo Fitting (TheIntegraGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheIntegraGuy &raquo;</TD></TR><TR><TD CLASS="quote">whatever works. </TD></TR></TABLE>
Old Oct 31, 2005 | 01:34 PM
ecahatch's Avatar
Senor Miembro
better than i can do as long as it works correctly
Old Oct 31, 2005 | 03:14 PM
kingSfit's Avatar
ur ghetto hung... just like me and my diy catch can hahahha u better use it
Old Nov 1, 2005 | 09:00 AM
Default Re: (bbun)
forreal..i am using it right now. i see no oil dude. whats up w/ it????
Old Nov 1, 2005 | 09:01 AM
zseeanz's Avatar
that's too much work for a $12 part. Good job though
Old Nov 1, 2005 | 09:22 AM
{Powered by VIII}'s Avatar
Default Re: Homemade DIY Turbo Fitting (zseeanz)
thats a pretty vital part to go ghetto on....
Old Nov 1, 2005 | 09:25 AM
jDm_jeremy's Avatar
Old Nov 1, 2005 | 09:26 AM
m R g S r's Avatar
Default Re: Homemade DIY Turbo Fitting ({Powered by R})
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Powered by R} &raquo;</TD></TR><TR><TD CLASS="quote">thats a pretty vital part to go ghetto on.... </TD></TR></TABLE>
Well I doubt it will break..loooks sturdy. But it may leak if the mating surface isn't completly flush.....
Old Nov 1, 2005 | 10:18 AM
al3e's Avatar
neato!
Old Nov 1, 2005 | 11:53 AM
yeah i put a gasket and the orange high temp silicon gasket maker to make sure no oil leaks out.
Old Nov 1, 2005 | 12:17 PM
VRD^sam's Avatar
VSM_EJ8_408
Northern California (Sales)
Jan 23, 2008 05:52 PM
hondaricers
Sep 21, 2006 02:12 AM
sleepingEg8
Jan 11, 2005 11:29 PM
sethm
Apr 20, 2004 02:00 PM
