ABS light is on
Old Oct 31, 2005 | 12:16 PM
cpudoc's Avatar
Default ABS light is on
I have a 1997 Honda Accord v6. The ABS light stays on. I brought the car to honda and the codes come up said it was low on fluid. They topped off the fluid in the ABS resevoir. When picked my car up the light was off when I started the car. The next time I started the car the light stayed on again. I checked the fluid and it was full to the top. Could the fluid level sensor be bad? Sometimes it's off when start the car and some it's on. Couild their be a lose wire?
Old Oct 31, 2005 | 01:23 PM
Chiovnidca's Avatar
Default Re: ABS light is on (cpudoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpudoc &raquo;</TD></TR><TR><TD CLASS="quote">Could the fluid level sensor be bad?</TD></TR></TABLE>
Nope, because the abs system doesn't have one. You most likely have air in the system and need to have it bled.
Old Oct 31, 2005 | 05:51 PM
lorunner1213's Avatar
The abs pump is gonna have to be blead. The same symptoms will return eventually if the plugs on the bottum of the pump are not retorqued properly. They cause the pump to leak and thats why the fluid was low.
mfrs
Sep 5, 2015 12:32 PM
turbo gsr
Sep 16, 2005 07:15 AM
hobbie88
Aug 26, 2005 10:52 PM
PleaseHelp
Aug 16, 2004 07:45 PM
