F22 and cam shaft
Old Oct 31, 2005 | 11:54 AM
gray_civic_coupe's Avatar
Default F22 and cam shaft
A friend of mine owns an accord 95 and he is planning to install a cam shaft into his F22 engine.
Is it nacessary to add or replace other parts in the engine if he is going to install the cam shaft?
Modified by gray_civic_coupe at 12:44 AM 11/1/2005
Old Oct 31, 2005 | 12:49 PM
Default Re: F22 and cam shaft (gray_civic_coupe)
bump
Old Oct 31, 2005 | 04:48 PM
gianinline's Avatar
If he is replacing because something was wrong... maybe...
...but if he is doing something to get extra horsepower... it should be a process of installing... ..checking your timing and... that's it!!!
BTW... if for performance reasons, too powerful cam shafts could damage the springs and valves within a few weeks..... ....then... all that would need to be replaced as well....
Old Oct 31, 2005 | 08:34 PM
momstaxi's Avatar
Default Re: (gianinline)
i dont think any aftermarket cam for the f22 has high enough lift and/or steep enough ramp angles to necessitate aftermarket valvesprings...but i could be wrong.
Old Nov 1, 2005 | 07:45 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (momstaxi)
other internals (valvetrain) would only need to be replaced if he removes the rev limiter and plans on revving higher. BUT it's better to be safe than sorry
kixcrx
Jan 3, 2008 03:16 AM
ramz7887
Apr 3, 2003 07:18 PM
