am i getting suckered on the price of install?
Old Oct 31, 2005 | 11:53 AM
chestnut_55's Avatar
Default am i getting suckered on the price of install?
hey guys. FedEx finally delivered my I/H/E this weekend. AEM short ram intake, Greddy SS 4-2-1 headers, Greddy Evo SS catback exhaust system, and stock replacement catalytic converter. My girlfriend wants to pay to get it installed as an early christmas present so i went and got a quote to install it all about 10 minutes ago. The shop does all my mechanical work but doesnt usually do any modification service. Everything is bolt on though so he quoted me about $125. I know, i know, i could do it all myself and save the money but its not coming out of my pocket and besides, i dont have a lift to get the car up in the air. and if something goes wrong, they are insured. is that price too high or will it be worth it to let the professionals do it?
Old Oct 31, 2005 | 12:01 PM
Slunk's Avatar
Default Re: am i getting suckered on the price of install? (chestnut_55)
sounds fair..
Old Oct 31, 2005 | 12:04 PM
P_Adams's Avatar
Considing that the prevailing Labor Rate in most shops now crowds $50.00/hr, He's cheap if you do the math. Even at $40.00/hr, that comes out to three (3) hours. I think it's reasonable
P
Old Oct 31, 2005 | 01:21 PM
hondabum's Avatar
wow what a good girlfriend, but save you money or hers, and DIY its easy the most easy thing to do is to put on you intake, then your h/e should be really easy also but you need tools and a dry place to do it, i did all that **** in under an 45mins. i know warrentys are nice, but think about it, do it your self and know how to do it, or have some one else do it and not know how to do it when somthing ***** up,,,, your choice. you said your girlfriend was going to pay for it well then ok go get it done but you should still put on your intake its sooooo easy if you dont know how just ask
Old Oct 31, 2005 | 01:59 PM
jin05's Avatar
its a fair price, but yea u should do the intake by urself at least. if u dont wanna install the header and exhaust.
Old Oct 31, 2005 | 02:07 PM
Default Re: am i getting suckered on the price of install? (jin05)
yeah i think i will install the intake myself. i was reading the instruction sheet for the short ram intake and it said something about draining a gallon of coolant before installing the intake. i dont understand why i would need to do that. it seems as simple as disconnecting the hoses and taking out the filterbox and plastic intake and then putting in the new intake. is the coolant draining really needed?
Old Oct 31, 2005 | 02:12 PM
hondabum's Avatar
no you dont need to drain a damn thing just take out the old **** and put in the new, its to easy did you call any exhaust shops and see how much they would charge?
Old Oct 31, 2005 | 02:13 PM
Default Re: am i getting suckered on the price of install? (hondabum4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life &raquo;</TD></TR><TR><TD CLASS="quote"> i know warrentys are nice, but think about it, do it your self and know how to do it, or have some one else do it and not know how to do it when somthing ***** up, </TD></TR></TABLE>
yeah i know how everything works, i took everything out of the boxes, laid it out and mocked it up to make sure everything is going to fit right. I easily think i could get it done by myself but i'm leary about messing with the headers. and as i said before, i dont have a lift to get the car up in the air like i would want to. i do appreciate the advice though. i would love to do most of the work myself, get my hands dirty and learn how to do it, but i generally understand how its done and am already quite confident that i could do it. so just how easy is it to install the intake?
Old Oct 31, 2005 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life &raquo;</TD></TR><TR><TD CLASS="quote">no you dont need to drain a damn thing just take out the old **** and put in the new, its to easy did you call any exhaust shops and see how much they would charge?</TD></TR></TABLE>
no i didnt but i should have. i've been going to this guy for as long as i've owned the car, he's a good friend of my father's and he's always helped me out when i needed it so he was the first guy i talked to.
Old Oct 31, 2005 | 02:19 PM
hondabum's Avatar
so easy !!!!! i did it in 5mins flat yeah a lift is nice i had a pit so that helped. well just go get it done for you, hay if your not paying for it than why the heck not and its so easy that if you did need to expletive with it because your warranty did not cover it, it would be easy,, yeah on second thought go get it done save your self the pain
Old Oct 31, 2005 | 02:32 PM
Eddiebx's Avatar
if you want do to it PROPERLY and not spill coolant yes you have to drain coolant out. most intakes for the 5g accord will come with a small coolant hose to by pass the stock metal pipe which will no longer be used.
Old Oct 31, 2005 | 02:42 PM
hondabum's Avatar
Default Re: am i getting suckered on the price of install? (Eddiebx)
well for m b2 it was not like that, maybe for a b1?what kinda block do you have?
Old Oct 31, 2005 | 03:52 PM
F22B1
so now im confused about the water bypass coolant hose thing. i didnt even know about that. so if i bypass it, then what......im confused. the intake only has one little outlet tig-welded to it but the kit came with two lengths of rubber hose. doesnt one of the hoses go to your pcv valve or something like that? what is the other one for?
Old Oct 31, 2005 | 04:33 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life &raquo;</TD></TR><TR><TD CLASS="quote">well for m b2 it was not like that, maybe for a b1?what kinda block do you have?</TD></TR></TABLE>
all 5g accords have that metal coolant pipe thing, it loops around i think from the theromostat to the throttle body or soemthing, i forget i haven't seen one in like 6yrs, haha.
its welded to the pipe that connectse between the stock intake arm and the breather port on the valve cover. ideally you would remove that pipe and replace it with a hose, but most ppl just overlook it and push it out of the way and call it a day.
Old Oct 31, 2005 | 04:43 PM
3rd Degree's Avatar
Sounds very fair to me. Most shops around here charge $60-$100/hr so that seems good to me. Infact, i might even concider taking my car to a shop for that price and that much work. Headers can be a bitch on an older car.
Old Nov 1, 2005 | 07:05 AM
Default Re: (Group A)
anyone installed greddy headers or an Evo system before? Greddy, to my knowledge, is a very good and trustworthy company, right? im worried about it all fitting right. i mocked it up and it seems ok but im leary. the mechanic said as long as everything was bolt up and they didnt have to modify it any, that he would install it. So i did good going with Greddy right?
Old Nov 1, 2005 | 07:38 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: am i getting suckered on the price of install? (f22b2power)
if it's not coming out of your pocket... who cares if he quotes you $10,000 for install
Old Nov 1, 2005 | 08:59 AM
CB5F22A1's Avatar
I'm a Jackass
Default Re: am i getting suckered on the price of install? (Vt4cPwn35)
im not trying to be an ***, but if your not confident about installing the intake, which is the simplest of the three, i wouldnt try to install the H/E myself if i were you. 125 is a very fair price for all three. go ahead and do it.
Old Nov 1, 2005 | 06:10 PM
Default Re: am i getting suckered on the price of install? (Crazy D)
the car goes in the shop tomorrow morning. i cant remember if the quote included installing the intake or not but my cousin said he would help me put it on this weekend. thanks for all the advice guys.
oh yeah. i got all new gaskets but i didnt get new bolts and springs for the exhaust. i should be ok using the old ones right? thanks again
Old Nov 1, 2005 | 06:16 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">if you want do to it PROPERLY and not spill coolant yes you have to drain coolant out. most intakes for the 5g accord will come with a small coolant hose to by pass the stock metal pipe which will no longer be used.</TD></TR></TABLE>
i honeslty have no idea what the expletive you are talking about....
care to elaborate with pics?
Old Nov 1, 2005 | 07:57 PM
hondabum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chestnut_55 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>yeah all the old **** will do fine just new gaskets <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
care to elaborate with pics? </TD></TR></TABLE> uuuh me to... what the fu&lt;k are you talking about
Old Nov 1, 2005 | 08:15 PM
dmurphy2k3's Avatar
I know its already been said, but your getting a good price compared to the shops in my area, especially with headers. As for those intake hoses, i didn't thinkt here was any coolent runing through them, i just thought they were for some sort of air sensor. When i installed mine, i plugged off one of them, and the other two hooked onto a T fitting which in turn hooked onto the intake.
Old Nov 1, 2005 | 09:02 PM
hondabum's Avatar
Default Re: am i getting suckered on the price of install? (dmurphy2k3)
yep
Old Nov 1, 2005 | 09:56 PM
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chestnut_55 &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a lift to get the car up in the air.</TD></TR></TABLE>
Here's a free "car lift"......drive one side of the vehicle onto a raised curb and leave the other side on the street. Bam. Instant car lift. If you plan on modding your car, you should get a set of tools, floor jack and some jack stands. It'll save you LOTS of money plus you'll be learning how to work on your own cars. Good luck with whatever you choose.......
Old Nov 1, 2005 | 10:05 PM
hondabum's Avatar
Default Re: am i getting suckered on the price of install? (MestizoRacer310)
i concur go and buy a jack and some tools,,,,, and a god damn book!!!!!!!no one wants to buy a book because they could just ask people on HT but **** people you need to GET A BOOK not sayn its an end all and once you get a book you know every little thing, i am just saying that it is a good place to start shop manual
