2000 ITR IDLE?
Old Oct 31, 2005 | 11:25 AM
bman511's Avatar
Default 2000 ITR IDLE?
I have a 2000 ITR and i was accelerating quickly, I went a little past 8000rpms. Missed 3rd gear. Now when it is idiling it idle's down to almost dying. And there is a ticking sound coming fromt the engine bay. Slow when at idle and then as you slowly accel it speeds up. I did get on it after that, and it still pulls hard as it ever did. Hopefully it's nothing serious! YOUR assistance is greatly appreciated! Thankyou in advance!
Old Oct 31, 2005 | 11:29 AM
Dave_B's Avatar
Did you pull the infamous money shift? You may want to perform a compression test and leak down test. These can guide you as to what to do next. Good luck on it, it can get rather expensive.
Old Oct 31, 2005 | 04:57 PM
PY TYPE R 483's Avatar
Default Re: 2000 ITR IDLE? (bman511)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bman511 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 ITR and i was accelerating quickly, I went a little past 8000rpms. Missed 3rd gear. Now when it is idiling it idle's down to almost dying. And there is a ticking sound coming fromt the engine bay. </TD></TR></TABLE>
Maybe a valve adjustment is needed?
Old Oct 31, 2005 | 05:03 PM
Kenso's Avatar
HT White Ops
Default Re: 2000 ITR IDLE? (PY TYPE R 483)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY TYPE R 483 &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe a valve adjustment is needed?</TD></TR></TABLE>
Valve adjustment isn't going to fix bent valves from an over-rev.
Old Oct 31, 2005 | 05:09 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bman511 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 ITR and i was accelerating quickly, I went a little past 8000rpms. Missed 3rd gear. Now when it is idiling it idle's down to almost dying. And there is a ticking sound coming fromt the engine bay. Slow when at idle and then as you slowly accel it speeds up. I did get on it after that, and it still pulls hard as it ever did. Hopefully it's nothing serious! YOUR assistance is greatly appreciated! Thankyou in advance! </TD></TR></TABLE>
for not searching.
Old Oct 31, 2005 | 05:12 PM
Default Re: 2000 ITR IDLE? (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">
Or new valves? </TD></TR></TABLE>
Thats what I meant to say, but I was trying to get the How to article on valve adjustment as well. My mistake.
Old Oct 31, 2005 | 05:37 PM
Shawn C's Avatar
In The Garage
or possibly a bent retainer?
Old Oct 31, 2005 | 05:48 PM
dsav4shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bman511 &raquo;</TD></TR><TR><TD CLASS="quote"> I went a little past 8000rpms. Missed 3rd gear. </TD></TR></TABLE>
How far is a little???
I have hit 9K before and no trouble... or so it seems.
Old Oct 31, 2005 | 06:00 PM
Reid's Avatar
Global Moderator
Default Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">or possibly a bent retainer?</TD></TR></TABLE>
How would a retainer get bent?
Sounds like bent valves.
Old Oct 31, 2005 | 06:40 PM
ITR-2001's Avatar
While at the track I also miss 4th gear and went into 3rd also..Lucky nothing happen (not trying to curse myself), but yea I was at redline in 3rd going to 4th but miss and went into 2nd. BTW if there is ticking sound from the engine bay I pretty sure you bent the valves
Old Oct 31, 2005 | 10:03 PM
bman511's Avatar
Default Re: (ITR-2001)
I appreciate everyone's help on this matter, one way or another this really sux! Does anyone know about how much it is for new valves, if they need to be replaced? or a valve adjustment? if need be? round about figures please? AS FAR AS THE HOW FAR QUESTION???? ABOUT 8,300-thankyou in advance!
Old Oct 31, 2005 | 10:22 PM
330R's Avatar
Default Re: (bman511)
When you say you missed third gear and saw approx. 8300 RPM... what exactly happened? You intended to upshift into 3rd gear, but what gear did you end up in? Or did your hand slip and you floored the gas in neutral? (which shouldn't result in a damaged valvetrain)
The redline is 8400 RPM, fuel cut (rev limiter) is 8600 RPM, and the tachometer tends to read a little high at those revs, so 8600 RPM looks more like 9000 on the tach.
Anyway, an indicated 8300RPM on an ITR engine is within its stock powerband.
Old Oct 31, 2005 | 10:28 PM
330R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bman511 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know about how much it is for new valves, if they need to be replaced? or a valve adjustment? if need be? round about figures please?!</TD></TR></TABLE>
It depends on how extensive the damage is. It's possible to bend only some valves, or all the exhaust valves, or all 16 valves, and even drop a valve and damage a piston.
You're looking at several hundred at least if you have bent valves.
Do an archived search for "bent valves" and read up. There's a couple of threads from folks with the symptoms who say they didn't overrev.
Modified by 330R at 1:40 AM 11/1/2005
Old Oct 31, 2005 | 10:40 PM
Stein's Avatar
Default Re: (330R)
Call the Acura dealer and order a set of valves, you're going to need them...
Old Nov 1, 2005 | 03:57 PM
mikestypeRR's Avatar
yes you bent your valves... my condolences.
Old Nov 1, 2005 | 07:09 PM
DubC TL's Avatar
Default Re: 2000 ITR IDLE? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">
for not searching.</TD></TR></TABLE>
Been covered MANY times.
Old Nov 3, 2005 | 08:24 PM
bman511's Avatar
Default Re: 2000 ITR IDLE? (DubC TL)
going to the shop next week, i will post and let you know what it is.....so stay tuned.
361 accord
May 16, 2008 08:25 PM
98IntegraLSNonVtec
Jul 28, 2006 11:04 PM
Interlude99
Aug 27, 2004 01:28 AM
Anubyss
Sep 7, 2002 09:39 PM
