Considering H22 swap into 4th gen.
Old Oct 31, 2005 | 10:55 AM
AP1's Avatar
AP1
Default Considering H22 swap into 4th gen.
I was looking to purchase a 4th gen prelude and do an H22 swap. I have a few questions off the bat.
Will I be able to swap the H22A type S engine, and if so, would I need the transmission as well from this engine? The OBDI ad OBDII thing seems to be a proble, so wouldi just change that as well?
Also what can I expect from performance? How will the car accelerate? My friend told me he raced a Prelude (4th gen) with an H22 in it with bolt ons and cams, and claimed to have beat him by about a car and a half in his mostly stock Civic Si. I found that hard to believe. Wouldn't a 4th gen with an H22 run at least mid to high 14's?
Thank you for any help,I've been searching the forums but I couldn't find anything that I could use.
Old Oct 31, 2005 | 11:05 AM
PrecisionH23a's Avatar
Default Re: Considering H22 swap into 4th gen. (mikeiswaydope)
Do an archived search.
https://honda-tech.com/zerothread?id=689805
http://www.hmotorsonline.com is a great place to purchase engines from. If you have a 96 you'll have to change from obd2-1. If you have a 92-95 you don't have to change anything if you get an obd1 engine. Stock H22 4th gens can cut high 14's so with a type S and minor bolt-ons I don't see why you couldn't run 14.5-14.8's.
Old Oct 31, 2005 | 11:09 AM
AP1's Avatar
AP1
Default Re: Considering H22 swap into 4th gen. (PrecisionH23a)
Would aiming for 13's all motor be a reasonable goal? Could I do it?
Thanks for your help
Old Oct 31, 2005 | 11:12 AM
Yes... you could do it. You'll most likely need some more goodies like EMS, fuel upgrades, tuning, etc etc.
Old Oct 31, 2005 | 11:43 AM
greatbiggiants's Avatar
Is a Type S swap legal in Cali, because of obd1 car obd2 motor, right.
Or do you have to convert the car to obd2 to? I know how to dell with the REF just want to know if i have to go to him.
Old Oct 31, 2005 | 07:45 PM
AP1's Avatar
AP1
So only one response? Mid to high 14's? nothing faster?
Old Oct 31, 2005 | 07:53 PM
Mad Hatter's Avatar
Default Re: (mikeiswaydope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeiswaydope &raquo;</TD></TR><TR><TD CLASS="quote">So only one response? Mid to high 14's? nothing faster?</TD></TR></TABLE>
stock? a type s h22 might, but a usdm one won't
a civic si could definitely beat an h22 prelude, maybe not by a car and a half, but it depends on the driver
Old Oct 31, 2005 | 07:59 PM
AP1's Avatar
AP1
The fourth gen, correct? Because I beat my friend's Si in my 5th gen all the time, by at least one and a half car lengths. Each time.
Old Oct 31, 2005 | 08:16 PM
Mad Hatter's Avatar
is your car stock? if you swap an h22 into a 4th gen, the only advantage that would have over a 5th gen is maybe 100 lbs... it shouldnt be much faster. most of the information you need can be found by doing a search
Old Oct 31, 2005 | 08:21 PM
AP1's Avatar
AP1
100 lbs? You're serious?
Old Oct 31, 2005 | 08:32 PM
Mad Hatter's Avatar
...or less, depends on the trim. type s h22 will also give you 20 more horses. if your friends si beat a 4th gen, it prolly had a reg h22 or jdm h22, not a type s
Old Nov 1, 2005 | 04:07 AM
jdmbreed's Avatar
Default Re: (i'm so lude)
i have a jdm h22 in my 4th gen, bone stock i would take a si with stage 1 cams camgears I/H/E i can take a h23 hatch ls hatch and the newer preludes i will just walk them.
Old Nov 1, 2005 | 07:13 AM
Turbo-GSR1287's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i’m so lude &raquo;</TD></TR><TR><TD CLASS="quote">
a civic si could definitely beat an h22 prelude, maybe not by a car and a half, but it depends on the driver</TD></TR></TABLE>
A CIvic SI beat an h22 prelude.......Is the h22 missing like every gear?...H22 Prelude &gt; Civic SI
Old Nov 1, 2005 | 09:23 AM
Mad Hatter's Avatar
Default Re: (-95LudeSI-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -95LudeSI- &raquo;</TD></TR><TR><TD CLASS="quote">H22 Prelude &gt; Civic SI </TD></TR></TABLE>
i agree, but its pretty close. if the prelude driver sucked at shifting, an si could easily beat one...or so i've been told
Modified by i'm so lude at 10:49 AM 11/1/2005
Old Nov 1, 2005 | 02:04 PM
petern101's Avatar
or if the prelude is an auto
Old Nov 2, 2005 | 05:57 AM
AP1's Avatar
AP1
So an H22A JDM Type S H22 will fit into a 4th gen? I won't need a tranny too, will I?
Also as for mods, I am going with JUN cams and I will be investing a lot in tuning. I want one sick All motor daily driver. ^^ Thanks for the help guys. How much do you think that swap will run me?
Old Nov 2, 2005 | 06:54 AM
mgags7's Avatar
this thread is so full of misinformation it is pissing me off
1) any H series tranny will fit any h series block.
2) civic Sis look stupid next to h22 preludes....you will kill them...you will also kill gsrs....if you get a few bolt ons...you will beat type rs
3)if youre gonna be doing cams and stuff like that, why dont you build a motor from the ground up instead of buying a swap....
get a 4th gen prelude
a jdm 4th gen m2b4 lsd transmission
find a usdm h23 block (the prelude you buy might have one)
get some arp studs for the h23
get the h23 bottom end balanced
find a h22 head, get it ported and put in the jun cams
find a stock intake manifold and have your head porter do some work on it
and an rmf or smsp header
then get a hondata s200 or s300 and tune that bi0ch
that will be daily driveable and sick....you will run low low 13s if you build it all right....
Old Nov 2, 2005 | 07:33 AM
Mad Hatter's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">this thread is so full of misinformation it is pissing me off</TD></TR></TABLE>
sorry...
to the op: why don't you just build up the 5th gen you have? since it already has an h22
Old Nov 2, 2005 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote"> 2) civic Sis look stupid next to h22 preludes....you will kill them...you will also kill gsrs....if you get a few bolt ons...you will beat type rs.</TD></TR></TABLE>
Now Here is a Man with Some Sense.......Mgags =
Old Nov 2, 2005 | 10:32 AM
AP1's Avatar
AP1
Mgags what are the benefits to using the H23 bottom end with the H22 head? Why not just swap the JDM Type S motor and already have the extra 20 horse?
Also are you sure on the low 13's? This is with a full interior,correct?
Old Nov 2, 2005 | 10:39 AM
mgags7's Avatar
i havent hit the strip yet with my recent changes...i will let everyone know when i do
the h23 bottom end will give you a 95mm stroke vs the 90.7 on the h22....that will pick up about 10-15 horse...and it will keep helping more as you upgrade more...and with the longer stroke you get higher compression with stock pistons...
the reason the type s motor makes more hp are 1)higher compression (which you will get with this setup)
2)bigger camshafts, and since you will be changing to jun cams, this is also taken care of...
so dont waste the money on a type s motor, the only difference will end up being a red valve cover...
Old Nov 2, 2005 | 10:43 AM
AP1's Avatar
AP1
Wanna keep in touch as I finish the project? How can I contact you for more info? I hate only being able to post 5 messages a day. -_-
98savage
Apr 10, 2007 08:54 PM
txl146
Feb 2, 2005 07:55 AM
Hotlude93
Nov 16, 2004 09:21 AM
91 lude si
Sep 6, 2004 03:02 PM
