does your brake fluid leak/evaporvate? mine does lol
Guest
Posts: n/a
i opened my brake cyclinder and what do you know... i'm half way down with brake fluid. i filled it up to the top a couple months ago, but i recently had a mishap (i had to slam on my brakes hard). i don't know if that's the cause of it but there's no signs of leaking either the floor or from the cyclinder. weird...
There are many places where you can leak brake fluid from. Check the lines on the chassis and at the calipers, check the firewall under the booster both inside and outside of the firewall, check the brake fluid reservoir cap.
Guest
Posts: n/a
i just rinsed it down... i check the cap daily and the booster seems to be leak free inside the engine bay and inside of my car (i'm gutted to sheetmetal). i drive it everyday just so i can figure out the problem.
UnrealSpeed
May 17, 2003 01:45 PM
Ehron
Mar 29, 2003 06:05 PM
