what suspension will work???
ok guys ive got a 93 civic hatch .. EG and im gettin a full disc conversion off a 99 civic si (front and back)... using si lca's ... will i have to get eg suspension or ek suspension?? or will both work?
so the rear suspension is the same on ek's and eg's ... but the front only depends on the fork .... so if i use the eg fork .. then i can use eg suspension .. but if i use the ek fork .. then i can use ek suspension
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob »</TD></TR><TR><TD CLASS="quote">it wont matter for the rears, but the fronts depend on which fork ur using</TD></TR></TABLE>
The rears DO IN FACT MATTER. if you're using EK LCA's, then get struts/shocks for an EK(you can get them for an EG too but you'll need a spacer becuase the EK LCAs are a tad bit smaller at the bushing). im pretty sure the fronts don't matter.
Momentum
May 6, 2009 10:43 AM
Demon_Dub
Sep 25, 2005 01:18 PM
EKwreckRLS
Sep 6, 2004 08:44 AM
