Synthetic...Yes or No?
Old Oct 31, 2005 | 09:23 AM
O RLY's Avatar
Default Synthetic...Yes or No?
Okay I just broke in my H22 after a quite extensive rebuild you can learn about by clicking the link in my signature. Anyways, we ran Shell Non-Detergent oil for about 500 miles, changing it three times already. I should be ready to run regular motor oil, and this I ask you:
Should I run a synthetic blend like Castrol GTX or Mobil 1. Or should I just run straight 5w30. I need to know which one will result in longer engine life and less ring wear. Please feel free to voice your opinion on the choice of oil you recommend.
Thanks, Rob.
Old Oct 31, 2005 | 09:30 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Synthetic...Yes or No? (JDMH22Civic)
I would use synthetic like Mobil 1, not a synthetic blend. I ran Mobil 1 in a Volkswagen GTI, and it reduced the engine temp., the GTI had a separate gauge other than water temp.
I also ran it in a 1989 Honda CRX Si, for 150,000 miles before I sold it. The compression readings for all four cylinders were always 190 190 190 190.
I am running it exclusively in a 1995 Honda Accord EX with over 215,000 miles, and still running strong.
Old Oct 31, 2005 | 09:36 AM
jadugartir's Avatar
Default Re: Synthetic...Yes or No? (tech8)
mobil 1. not syntec, not regular oil, mobil 1.
my car will never taste a drop of any other oil, and neither should yours. Whether you have a 10 year old beat up motor or a brand new rebuild, nothing beats synthetic. i would use a mobil 1 or k&n oil filter as well. you can leave them in for 5000 miles, and you can leave mobil 1 in your car for 10k no problem. I always get bored and change it before 3000, but its nice to know that i dont have to.
Old Oct 31, 2005 | 10:01 AM
O RLY's Avatar
Default Re: Synthetic...Yes or No? (jadugartir)
Hmm, Mobil1 seems to be the favorite here. Anybody else. Thanks guys!
Old Oct 31, 2005 | 10:22 AM
violence_hero's Avatar
Seeing as how you're planning on going FI you might as well as use synthetic. Mobil 1 is certainly the most available, that's for sure.
Old Oct 31, 2005 | 10:29 AM
xomp's Avatar
Default Re: Synthetic...Yes or No? (violence_hero)
i use mobil1 5w30
Old Oct 31, 2005 | 10:35 AM
cambopheonix56's Avatar
Default Re: Synthetic...Yes or No? (xomp)
look into ams oil. it cost more then mobil 1 but its protects better.
Mobil 1 vs ams oil
i run ams oil and i like it.
Old Oct 31, 2005 | 10:36 AM
EG2Driver's Avatar
if u wanna go ***** to the wall u can use royal purple.....doesnt get any better than that. Mobil 1 will do great for a lot cheaper.
Old Oct 31, 2005 | 11:12 AM
94hatchling's Avatar
Default Re: Synthetic...Yes or No? (deadend9009)
i prefer royal purple personally. its all i've used so far in my swap. pulled the valve cover recently, still just like new. thats my preference. mobil 1 is good as well.
Old Oct 31, 2005 | 11:30 AM
si0385.'s Avatar
Default Re: Synthetic...Yes or No? (94hatchling)
ams oil
mobil1
royal purple
castrol GTX
Old Oct 31, 2005 | 12:34 PM
ZzZCivicZzZ's Avatar
Mobil1
Old Oct 31, 2005 | 12:38 PM
Ricey McRicerton's Avatar
Default Re: (ZzZCivicZzZ)
I've been running Mobil1 SuperSyn for close to 50k on my Civic both boosted and all motor.
Old Oct 31, 2005 | 02:34 PM
EGmikeH22's Avatar
* B A N N E D *
yes
royal purple
Old Oct 31, 2005 | 02:39 PM
dewoine's Avatar
Default Re: (EGmikeH22)
castrol syntec
never had a problem with it
Old Oct 31, 2005 | 02:42 PM
EK k kay's Avatar
Default Re: (dewoine)
If you change your oil regularly then you don't really need synthetic.
Old Oct 31, 2005 | 02:44 PM
TorganFM.'s Avatar
Castrol syntec is a pseudo synthetic. It's actually made from dino oil. I'm about to put some Syntec 5w50 in my car with a very tired d15b7, we'll see how it goes. Oil with such a large viscosity range doesn't maintain the advertised viscosity as long, and is more likely to foul up earlier from what I've read.
Old Oct 31, 2005 | 02:45 PM
Slow EJ8's Avatar
Default Re: Synthetic...Yes or No? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">look into ams oil. it cost more then mobil 1 but its protects better.
Mobil 1 vs ams oil
i run ams oil and i like it.</TD></TR></TABLE>
According to their site it says
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The only 25,000 mile/one- year and 35,000/one- year motor oil in the world. </TD></TR></TABLE>
I am no oil expert but it seems wierd to me that oil could last and protect well that long. Apparently it can and if indeed it can is the higher cost offset by the less frequent oil changes needed?
As for Mobil1 it is prob the most popular and widely available synthetic. I just use regular non-synthetic oil and change every 3000-4000 miles. Im kinda worried about switching to synthetic but Im not sure why lol
Old Oct 31, 2005 | 03:25 PM
shakedown94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZzZCivicZzZ &raquo;</TD></TR><TR><TD CLASS="quote">Mobil1</TD></TR></TABLE>
when i was in the USMC i worked as a eng mechanic on f/a-18. the oil we used came in a generic, military labeled cans. but as a case, the box itself sad mfg by mobil 1. nuff said for me
now, not the same stuff. but, if they can fiqure out how to make it work in jets, our
engs will be cake.
Old Nov 5, 2005 | 02:35 PM
DB1_559's Avatar
castrol is the best and someone told me its the only oil to use cause its a honda motor
Old Nov 5, 2005 | 02:39 PM
Padawan's Avatar
Darth ModerVader
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">If you change your oil regularly then you don't really need synthetic.</TD></TR></TABLE>
Exactly. A well-maintained Honda engine running conventional motor oil will last a very long time.
Old Nov 5, 2005 | 04:39 PM
bmoua's Avatar
i've been using castrol 10w30 on my EJ8 for the past 13k and its been great...cant go wrong...
HA0589
31
Mar 5, 2014 09:09 PM
newbie2012
Oct 26, 2012 04:23 PM
lstncls7
Jul 13, 2005 03:52 PM
Nextelbuddy
Feb 20, 2004 05:51 PM
Kelvin96GSR
Nov 29, 2001 01:18 AM
