ecu help on 88 crx
Old Oct 30, 2005 | 11:33 PM
KiLlInG 562's Avatar
Default ecu help on 88 crx
i am doing a motor swap and i have a question for you.
i have a 1988 CRX DX and i'm swaping in a 94-95 B18B w/90 Integra ECU.
Now well the stock wiring from the 88CRX plug and play into the 90 Integra ECU??
This is what i have for the swap:
94-95 Integra B18B w/91 tranny
91 Integra Axels
90 Integra ECU
90-91 Integra Motor Harness
90 Integra Dist
Hasport mounts
Hasport Shift Linkage
PLEASE LET ME KNOW IF ALL THIS WELL WORK WITH EACHOTHER!
ps does anyone kow how to rewire the 91 dist wire to the 95-94 dist plug wire??
thanks
B
Old Oct 31, 2005 | 11:34 AM
FOMULA91's Avatar
Default Re: ecu help on 88 crx (KiLlInG 562)
PR4 or PG7? Anyway they should both work.
Old Oct 31, 2005 | 11:38 AM
zccr-xsi's Avatar
i got a pr4 for sale.u want it??
Old Oct 31, 2005 | 11:43 AM
Default Re: (vteckillenzc)
What the expletive is all this PR4 and PG7 **** that i read all the time??
can you please break it down for me!
B
Old Oct 31, 2005 | 01:12 PM
ktp1798's Avatar
Doesn't he need the resistor box and injectors?
Old Oct 31, 2005 | 02:02 PM
Mach69's Avatar
Default Re: ecu help on 88 crx (FOMULA91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">PR4 or PG7? Anyway they should both work.</TD></TR></TABLE>
PR4. The pg7 is for the d16a1. For the record, both ecus are plug and play with the 88 dx harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ktp1798 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't he need the resistor box and injectors?</TD></TR></TABLE>
I think you meant to ask if he needs to convert to mpfi. Yes, before you do the swap you must convert to mpfi.
Old Oct 31, 2005 | 03:33 PM
Default Re: ecu help on 88 crx (Mach69)
Yeah,
I also have the resistor box and the injectors.
the resistor box is off the 90-91 harness
and the injectors are from the 94-95 motor
please feel free to make corrections if the parts that i have don't work with eachother PLEASE
Old Oct 31, 2005 | 03:41 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiLlInG 562 &raquo;</TD></TR><TR><TD CLASS="quote">the resistor box is off the 90-91 harness
Here is your first correction: 94-95 injectors are obd1 or obd2, i forget. Regardless, they work without an injector box, as they as high impedence. The 90-91 obd0 injectors are the same flow rate (240cc i believe) and work with the resistor box.
Old Nov 1, 2005 | 08:18 AM
Thanks for the info!
Please keep it coming.
Old Nov 2, 2005 | 10:28 AM
need more help!!
Please help
818blue818
Oct 10, 2008 07:10 PM
exotik4doorcivic
Mar 4, 2007 11:24 PM
88cerx
Feb 27, 2005 11:45 PM
crew08 (girlygirlracer)
Mar 23, 2003 03:40 PM
VTECVillain
Jan 1, 2002 04:40 PM
