which wiring harness to use???
Old Oct 30, 2005 | 09:12 PM
all4show97's Avatar
Default which wiring harness to use???
I have a 1997 civic DX coupe and am swapping an obd1 b18c1 into it. I have a DX harness , the GSR harness and an HX harness. Some have told me to buy a 96-98ex harness is this necessary or can i use one of the harness' i already have. Any help would be appreciated.
Old Oct 30, 2005 | 10:36 PM
THEUSED's Avatar
Your obd1 b18c1 harness will work
Old Oct 30, 2005 | 10:52 PM
akteamster's Avatar
Default Re: which wiring harness to use??? (all4show97)
if u use the 96-98 EX harness, u will save ur self wiring problems,
u can use ur DX harness but u will have to change some plug sensors and off course run the vtec wires.... i THINK u can use the HX harness, i was told it is the same as the ex harness xcept for an addition plug or 2, but dont quote me on this.
here is a very useful link that i also found helpful since i am starting my swap tom
(type r in a 96 civic DX)
http://www.phear7imports.net/trey/6gen/
Old Nov 2, 2005 | 10:12 AM
jdmcars.com's Avatar
Default Re: which wiring harness to use??? (akteamster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster &raquo;</TD></TR><TR><TD CLASS="quote">if u use the 96-98 EX harness, u will save ur self wiring problems,
http://www.phear7imports.net/trey/6gen/</TD></TR></TABLE>
Said statements above are true and the easiest. However, you didn't state the years of the DX or HX harness, and this could be a problem. If they are out of the 96-97, all will work, but the #1 option would be EX, then HX, and DX.
Old Nov 2, 2005 | 02:14 PM
all4show97's Avatar
Default Re: which wiring harness to use??? (jdmcars.com)
Thanks for the help everybody im just goin to buy an EX harness.
Old Nov 6, 2005 | 01:44 PM
SHG_EasyE's Avatar
hey guys im doing the same thing- 94 obd1 gsr into a 96 hatch.... so all you need is the ex wiring harness?? this will make it possible to pass inspection and work with the obd2 inspection machine? what else is needed? ecu? injectors? distributor?
noones been answering any of my questions! thnaks for the help in advance!
Timothy Yhtomit
Feb 26, 2019 02:25 PM
hondaek2nr
Nov 23, 2008 06:58 PM
BigRonDawg
Apr 24, 2006 06:04 AM
99'b16at
Oct 15, 2005 09:27 AM
