Clutch problem
Old Oct 30, 2005 | 06:52 PM
kevinm1981's Avatar
Default Clutch problem
I jumped in my car and the clutch pedal went straight to the floor and there is no resistance at all. Help needed ASAP.
Old Oct 30, 2005 | 06:56 PM
hondabum's Avatar
Default Re: Clutch problem (kevinm1981)
maybe your slave or master cylinder did you check for leaking fluid
Modified by hondabum4life at 4:45 PM 10/31/2005
Old Oct 30, 2005 | 07:54 PM
JDM4DRACCORD's Avatar
Your not "Fucked" that a easy job to do. You might as well replace the slave and the master. Go on eBay there are some great package deals.
Old Oct 31, 2005 | 01:35 PM
kevinm1981's Avatar
Default Re: (hondabum4life)
I'm not sure if it's the cylinders, the pedal just flips back and forth. It clicks back and forth.
Old Oct 31, 2005 | 02:15 PM
P_Adams's Avatar
Default Re: (kevinm1981)
B4 you start running around all wide eyed waving your arms, check for fluid in the Clutch Master Cylinder.
If there is none.......refill it and bleed the system.
...and start looking for a leak.
If there is fluid, most likely the Clutch Master Cylinder took a sabbatical.
Hers' a picture of what you're dealing with:
http://www.hondaautomotivepart...INDER
This is, of course, assuming you've got a 5Th Gen Accord. You never mentioned.
P
Old Oct 31, 2005 | 03:39 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm1981 &raquo;</TD></TR><TR><TD CLASS="quote">I jumped in my car and the clutch pedal went straight to the floor and there is no resistance at all. Help needed ASAP.</TD></TR></TABLE>
get a flashlite, look under the dash where the clutch pedal rod goes into the cylinder, if u see any fluid at all the master is leaking, look at the slave cylinder , pull the boot back chk for fluid if u see any it is leaking as well..........if u do replace master pay close attention at the return spring at the pedal how it is installed
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
vinceg143
Sep 9, 2008 07:14 AM
GraphiteMW
Mar 25, 2007 09:26 AM
92eg6lsvtec
May 20, 2006 05:56 AM
aengnr1
Jun 16, 2003 12:23 PM
