camber kits need some opinions
Old Oct 30, 2005 | 06:51 PM
david
Guest
Posts: n/a
Default camber kits need some opinions
so what kind of camber kit is everybody running in here? my car is butterflied pretty bad and i'm going through tires like a mother even with my alignment. i never purchased a camber kit in my life and i know squat about them except what they're used for. i would like to know a reputable brand (1 set for the rear and 1 set for the front) and a price range i should be looking at. thanks in advance.
edit: anybody in here hear of the washer trick for the rear?
Modified by david at 9:58 PM 10/30/2005
Old Oct 30, 2005 | 06:53 PM
-L@ndry-'s Avatar
Default Re: camber kits need some opinions (david)
this is what i got. Good price and Good quality.
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Oct 30, 2005 | 08:02 PM
david
Guest
Posts: n/a
anybody that sells both?
Old Oct 30, 2005 | 08:15 PM
92bubblesi's Avatar
Skunk2 in the front. It seems to do well, although I have not had the car professionally aliged yet. I just bought a skunk2 kit for the rear but have yet to install it. Once I get the rear installed it will be time to get it aliged.
Old Oct 30, 2005 | 08:50 PM
6doorsentra's Avatar
SKunk2 in front and rear, get allignment. 150 for front and same for rear.
Old Oct 30, 2005 | 08:54 PM
my_slow_civic's Avatar
Omni's front kit is top notch. They even send you longer bolts and shims for the rears.
Old Oct 30, 2005 | 08:59 PM
david
Guest
Posts: n/a
Default Re: camber kits need some opinions (my_slow_civic)
any sponsors in ht selling the omni 1's?
Old Oct 30, 2005 | 09:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">any sponsors in ht selling the omni 1's?</TD></TR></TABLE>
Yeah, I purchased mine from this guy: https://honda-tech.com/zerothread?id=1179927
$165 shipped, and I had them pretty quick. I believe it was three days or so.
Old Oct 30, 2005 | 09:28 PM
JDM-EJ1's Avatar
I've heard great things about Ingal's and Skunk2.
Old Oct 30, 2005 | 09:31 PM
Default Re: camber kits need some opinions (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard great things about Ingal's and Skunk2.</TD></TR></TABLE>
I was disappointed in the Ingals kit, when I had my EF. It was the older style, that replaced the two bushings on the front control arms. Once adjusted, it lifted the front end of the car roughly an 1". So, the front end always sat higher than the rear.
Old Oct 30, 2005 | 09:33 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">I was disappointed in the Ingals kit, when I had my EF. It was the older style, that replaced the two bushings on the front control arms. Once adjusted, it lifted the front end of the car roughly an 1". So, the front end always sat higher than the rear.</TD></TR></TABLE>
Hmm.. The kits I've heard about, I'm not sure if they were the 'older' or 'newer' kits.. I will definitely keep this in mind when buying my camber kit.
Old Oct 30, 2005 | 10:14 PM
EJ8 Jim's Avatar
I was pleased with my front skunk2's (offer over +/- 4 of adjustability) Can find them on ebay for about $150 - some with free shipping.
I have pictures of them on my cardomain.
Old Oct 30, 2005 | 10:16 PM
neutron91's Avatar
as you adjust the camber closer and closer to 0 degrees it will gradually "raise the car back up" since it has been pushed so far negative after a big drop... i think you had a problem elsewhere and not the kit... ive had ingalls on every honda ive owned and never had a problem with the front being higher than the back
Old Oct 30, 2005 | 10:22 PM
dpetro1's Avatar
Default Re: camber kits need some opinions (neutron91)
im using the omni front upper arms and the shims in the rear. came as a package with my suspension setup. they also have an actual rear camber kit too lookin at about 150 up font and 100 in the rear. pretty much the same thing as the skunks
Old Oct 30, 2005 | 10:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">
as you adjust the camber closer and closer to 0 degrees it will gradually "raise the car back up" since it has been pushed so far negative after a big drop... i think you had a problem elsewhere and not the kit... ive had ingalls on every honda ive owned and never had a problem with the front being higher than the back</TD></TR></TABLE>
No, it was a issue with the kit. I uderstand the waya camber kit like that will "raise the car". While I enjoyed correct camber, the issue of the heigth difference was probably noticed more by me, than anyone else. I even had a rep from Ingalls contact me with a few things to try. He apparantly read one of my posts somewhere about it. This was before they had the ball joint kits.
Old Oct 30, 2005 | 10:28 PM
neutron91's Avatar
hmmm... thats weird... i never had that problem with any of mine... what did he tell you to try to fix it... just curious
Old Oct 30, 2005 | 10:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm... thats weird... i never had that problem with any of mine... what did he tell you to try to fix it... just curious</TD></TR></TABLE>
It's been a few years. The main thing I remember was, I should jack the car up, until the wheels were off the ground. Once they were off, loosen the bolts from the control arm. Then, lowere the car, and allow it to settle. Once that was done, I needed to cram my hand up under there, and then tighten the bolts down. He wondered if some how the bushing was binding.
I think now, it was probably the wrong application for my suspension setup. And I was probably really the only one who could tell it was like that.
Old Oct 30, 2005 | 11:12 PM
nathan23h's Avatar
Skunk2 Front & Ingalls Rear seems to work great. Love the adjustability of the Skunks
Old Oct 31, 2005 | 12:35 AM
IT'S ME DAVID's Avatar
NooB
i had ingralls in front and rear in my old ef car dropped 2" tenzo springs this was in 2000 and it worked good.
Old Oct 31, 2005 | 01:46 AM
O16581724 5 2 5's Avatar
Default Re: camber kits need some opinions (K SERIES)
Advance Autoparts sells 3 degree adjustable front ball joints.
Old Oct 31, 2005 | 02:39 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: camber kits need some opinions (O16581724 5 2 5)
Omni. Had them for over a year. No troubles, bubbles.
NONvtecLSteg
Nov 10, 2012 11:04 AM
Aftermath_Hatch
51
Dec 17, 2009 08:27 AM
Flux
Jun 9, 2003 05:10 PM
done
Jan 21, 2003 05:32 PM
AMG
Nov 30, 2002 09:15 AM
