f22b2 swap 2 a h22a
f22b2 is the vtec sohc that came in the 5th gen right? if so... you can use your stock accord mounts cept for the driver's side mount... you will need the stock prelude mount for that side & your set. No need for "custom" ones...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 »</TD></TR><TR><TD CLASS="quote">f22b2 is the vtec sohc that came in the 5th gen right? if so... you can use your stock accord mounts cept for the driver's side mount... you will need the stock prelude mount for that side & your set. No need for "custom" ones...
f22b2 is non-vtec - f22b1 is... but mounts should be the same since the block is the same...
</TD></TR></TABLE>f22b2 is non-vtec - f22b1 is... but mounts should be the same since the block is the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-Gore »</TD></TR><TR><TD CLASS="quote">
f22b2 is non-vtec - f22b1 is... but mounts should be the same since the block is the same...</TD></TR></TABLE>
oh ok, got the #'s confused... been a while since ive had my f series
like i said before tho... you can use all your stock accord mounts accept for the drivers side mount.. you will need the stock prelude mount for that side.
candymanjl
Oct 9, 2006 08:13 AM
CanuckCRX
Aug 19, 2003 07:19 AM
b18c4door
Jul 31, 2003 11:51 PM
