Fog lights on a 96 civic with a 99-00 front conversion?
Are the switch harness the same... im having trouble wiring it under the dash i have the front hook up with the fog light connector from the engine bay.
i have 5 connectors ones for the relay and ground and then ones to the switch i have no clue were the other ones go... is it because its a harness for a 99-00 and im hooking it up to a 96 civic. if so what did you guys do?? thanks or any help
hay sup, i did the conversion my self also.. i have a 98 and i converted my front end to a 00' all the wire harness are the same. under the dash it was hard to find but u will find a brown it has a blue tape... WAY behind the fuse box.. its there...
than i painted them
and heres a lil help
http://www.handaaccessories.co...s.pdf
page 8 0f 10 step number 31
its the same for my car which was a 98
than i painted them
so nothing hooks up to the harness thats on the light switch of the car? where do the others plug into? thanks for the help maybe i need to look harder.. i was trying to do this at night so didnt really look hard enough.
yes u are gonna use all the harness all the harness should connect. use that website i gave u its really help full.. and if u wanna turn on ur foglights while u have ur daytime runnin lights let me kno i have a site for that too ..
goodluckk
u have any pics of ur conversion? im doin my car now.. im just waiting on my grille cuz i just lost mines ... and my lips should be commin in this week .. and paint job .. my area went thru the hurrican Wilma .. and it almost took my cars life
and my girl wanted me to park the night of the hurrican there ... thank God i never listen to my girl
goodluckk
can i get that site? what is done differently to have that? so when i hook it up i wont be able to have my fog lights turn on unless my lights are on?
i will try to have pics up when i get the lights done
u might need adobe reader for it.. the linked work for me ... well the factory settin only lets u use the foglights when u have the low beams on.. not on high beams nor when u have ur parkin lights on ... so theres a lil trick they got that can eliminate that
http://www.jimmmmmmmah.com/Ins...s.htm
thanks for the bump im stuck with these two plugs it suppose to go into the factory light harness but it dosent
Modified by ALL MoToR Ek9 at 5:09 PM 11/1/2005
kentk808
Jul 31, 2013 02:02 PM
CHAMPwhteEK
Apr 3, 2009 02:13 PM
Ghetto Civic HX
Nov 14, 2007 07:53 AM
ghostsi69
Audio / Security / Video
Mar 26, 2006 09:15 AM
