OBD1conversion,which scanner to use for CEL??
Old Oct 30, 2005 | 02:33 PM
RedEj8's Avatar
Default OBD1conversion,which scanner to use for CEL??
Ok i have a 97 civic with an obd1 conversion harness and a p28 ecu..I got a CEL and i need to know which scanner to use to check the engine light.Would i use a obd1 scanner or an obd2 scanner? Thanks -Baker
Old Oct 30, 2005 | 02:37 PM
EGmikeH22's Avatar
* B A N N E D *
just jump the plug under the dash and look the code up, no scanner necessary with OBD1 ECUs.
not sure exactly where the plug is on the EKs, but I know thats how it works with a conversion harness.
Old Oct 31, 2005 | 02:59 PM
Civic Racer X 7's Avatar
the plug i right above the ecu
just stick a paper clip in it and jump the 2 ports together
spool310
Sep 6, 2006 10:02 AM
Azn Kenny
Oct 5, 2005 12:27 PM
stevieteg
May 17, 2004 11:35 AM
BringIT
Jan 23, 2004 05:24 PM
zCivic
Feb 9, 2003 01:30 PM
