DIY: Cabin Air Cleaner/Filter thing
Old Oct 30, 2005 | 01:44 PM
_gurusan_'s Avatar
Default DIY: Cabin Air Cleaner/Filter thing
Ok well I removed the A/C system from my civic to reduce parasitic lag and strip some weight.
Now, if you're like me and have horrible allergies, or just like clean air, then here's a little write up you might appreciate. This won't give you any power gains or make your mad vtack scream, but it will clean the air so you don't sneeze on teh hot beazy in the passenger seat.
Step one begins assuming you have removed the entire A/C system except for the drier under the passenger side dash.
1) Remove drier under pass. side dash. Be careful of the SRS unit to the left of it, my Haynes manual recommended disconnecting it while you work in that area to reduce the risk of the airbag(s) deploying in the general direction of your large dome. There are just a few bolts and screws holding it on, I found it easier if I removed the glove box support first. (sorry no pics, figure it out ladies)
2) Once you have the drier removed, pop off the clips holding the 2 halves together, and there is a screw or 2 to remove also. Pull the halves apart and remove the drier unit.
....hehe i wonder if you could make the drier unit into some kind of SMIC or oil cooler....
3) Go to the hardware store and buy a household air cleaner element. I bought a fine microfiber filter from Ace hardware. You will need to cut the filter element down to size.
I measured first and cut it to roughly 9.5 x 11.
It looks like this when it's in...make sure to press along the edges to seal it as best you can so the majority of air passes through the filter.
4)
To seal the hole in the firewall from where you pulled the drier lines from, remove the grommet thingy, find something to seal it up with, and glue it. I cut the plastic top off a container and used silicone adhesive to seal it up.
All dry and ghettotastic
Pop it back in the hole
5) Reinstall the new air cleaner box and you're done! No more dirty *** air!
The only thing about this is you'll need to change it periodically. I'm just going to change mine 2 or 3 times a year. It probably depends on the filter you are using also.
Copyright 2005: teh gurusan master
Old Oct 30, 2005 | 01:47 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: DIY: Cabin Air Cleaner/Filter thing (_gurusan_)
A for effort. Nice copywright.
Old Oct 30, 2005 | 02:03 PM
AnToNy's Avatar
Wow, pretty good idea.
Nice write up
Old Oct 30, 2005 | 02:05 PM
.Ry's Avatar
.Ry
Default Re: DIY: Cabin Air Cleaner/Filter thing (AnToNy)
o
Old Oct 30, 2005 | 02:08 PM
markysparky's Avatar
ohh ahhh!!! fresh air yummmmmm
Old Oct 30, 2005 | 03:19 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (markysparky)
Ive been looking for **** like this for months. Damn you man, now I have more work to do and something else to build. Thanks.
Old Oct 30, 2005 | 03:47 PM
_gurusan_'s Avatar
Default Re: (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Ive been looking for **** like this for months. Damn you man, now I have more work to do and something else to build. Thanks.</TD></TR></TABLE>
No problem. Glad I'm able to contribute something after all the info i've absorbed from HT and other forums
Old Oct 30, 2005 | 04:01 PM
ecahatch's Avatar
Senor Miembro
Default Re: DIY: Cabin Air Cleaner/Filter thing (litterbox)
nice
Old Oct 30, 2005 | 04:20 PM
Cory Matthews's Avatar
Default Re: DIY: Cabin Air Cleaner/Filter thing (ECAhatch)
wait the car doesn't have one stock already?
Old Oct 30, 2005 | 04:25 PM
_gurusan_'s Avatar
Default Re: DIY: Cabin Air Cleaner/Filter thing (z6 coupe)
Nope....in the mid-early 90s most cars didn't have any.....especially econoboxes
Old Oct 30, 2005 | 05:28 PM
transpar_nt's Avatar
I was wanting to do this during the summer but couldn't find any writeups or anything and never got around to ripping it all apart. Thanks for the help!
BTW, the cabin filters in hondas only started in 96 in the accords, and slowly made its way into all of the other vehicles. (This is strictly Honda not Acura; I asked at a Honda dealership).
Old Oct 30, 2005 | 05:31 PM
808_si's Avatar
cool idea. good work!
Old Oct 30, 2005 | 05:34 PM
_gurusan_'s Avatar
Default Re: (808_si)
thanks for the replies guys.
And for those that want to retain A/C you can fit a filter in there...but I think a filter AND the drier might affect how strong it blows.
Old Oct 30, 2005 | 08:25 PM
_gurusan_'s Avatar
Default Re: (_gurusan_)
bump for the bubble boys
Old Oct 30, 2005 | 09:19 PM
hybrid_vtec's Avatar
Honda has one made for your car. It's called and A/C plug and runs around $5. Look for the models that do not have A/C!
Old Oct 30, 2005 | 09:28 PM
_gurusan_'s Avatar
Default Re: (hybrid_vtec)
Yeah I know about them but didn;t want to spend the $$ on something I could get do for
free.
thanks though
Old Oct 31, 2005 | 07:25 PM
_gurusan_'s Avatar
bizzle
Old Oct 31, 2005 | 10:03 PM
RedEK9's Avatar
Old Nov 1, 2005 | 04:01 PM
BLUE EH3's Avatar
Help we my pennies
WHERE IS THAT AT?
Old Nov 1, 2005 | 04:14 PM
_gurusan_'s Avatar
Default Re: (BLUE EH3)
WHERE IS WHAT AT!?
Old Nov 1, 2005 | 05:16 PM
THAT THING!!!eleven!!! WHERE IS THAT THING AT THAT THE GUY WAS TALKING ABOUT TO THAT OTHER GUY? IT HAD THIS PART THAT DID SOMETHING!
Old Nov 1, 2005 | 06:15 PM
_gurusan_'s Avatar
Default Re: (transpar_nt)
ugghh?
Old Nov 13, 2005 | 06:59 AM
BLUE EH3's Avatar
Help we my pennies
i would like a cabin filer, but i need more detals, wherea are the ac drier? canup post pics
Old Nov 13, 2005 | 08:16 AM
Extreme's Avatar
the drier he's referring to is actually the a/c evaporator.
Old Nov 13, 2005 | 09:05 AM
PhoebeusFenix's Avatar
Anybody happen to have a link to removing the a/c system?
