LS block or GSR for my EM1
Old Oct 30, 2005 | 11:38 AM
kidd_drastic's Avatar
Default LS block or GSR for my EM1
I'm going for an all motor setup. b16 head on either ls or gsr short block. im planning to get this short block
https://honda-tech.com/zerothread?id=1415277
i was wondering if this block with gsr rods and oversized ctr pistons has the potential to have more power than an ls block with ctr pistons. also if this short block is a good deal for 500.
Old Oct 30, 2005 | 11:51 AM
GEIJIN's Avatar
Default Re: LS block or GSR for my EM1 (kidd_drastic)
go with the gsr for a mini hype-R settup
Old Oct 30, 2005 | 11:53 AM
Archidictus's Avatar
Unceasing Measure
Default Re: LS block or GSR for my EM1 (EINSTEIN)
GSR has a rod/stroke more in tune with the revs you'll have to put through it to make serious power in an NA formulation .
Old Oct 30, 2005 | 12:28 PM
JDM-EJ1's Avatar
GSR.
Old Oct 30, 2005 | 01:00 PM
black_EM1's Avatar
Community Builder
Community Influencer
IDK... With the LS, you'll get this crazy thing called torque, but...... poor mans type r setup is good as well. You swap the LS crank in for a longer stroke as well
Old Oct 30, 2005 | 01:12 PM
Micha's Avatar
FAILWGN
Default Re: (black_dohc)
Go with the GSR block. You will make up for the lack of torque with higher revs. 500 isnt bad if you know what you want to do with it. Pretty cheap actually.
russianswty
Oct 17, 2006 03:09 PM
kidd_drastic
Oct 30, 2005 11:52 AM
arielmalespin
Apr 27, 2005 11:24 AM
EK FLY
Jan 27, 2005 10:57 PM
