b16 transmission rebuild...?
Old Oct 30, 2005 | 11:23 AM
AMECustom's Avatar
Default b16 transmission rebuild...?
I dont know the code for the trans but its from a JDM b16a motor. I need to rebuild it due to third, fourth, and fifth starting to grind. Plus it might sell better in tEH future.
I am a noob at this but i will have experienced people helping me out during the rebuild. I want to find out any writeups on here showing how to get the job done. I also want to know how much i'm looking to spend plus the best tools possible to get the job done.
Please help me i want do due this during my winter break from school...i have 5 weeks hopefully that will be enough time.
Old Oct 31, 2005 | 02:53 AM
xxwhixx's Avatar
Default Re: b16 transmission rebuild...? (AMECustom)
if i was you i would have someone do it if you have not done it before i was gonna attemp this also but i called a couple people and everyone i talked to said dont do it you take the case apart and i heard that **** falls out every were like springs and little parts you will prolly never figure how to put it back together
Old Oct 31, 2005 | 04:29 AM
AMECustom's Avatar
Default Re: b16 transmission rebuild...? (xxwhixx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxwhixx &raquo;</TD></TR><TR><TD CLASS="quote">if i was you i would have someone do it if you have not done it before i was gonna attemp this also but i called a couple people and everyone i talked to said dont do it you take the case apart and i heard that **** falls out every were like springs and little parts you will prolly never figure how to put it back together </TD></TR></TABLE>
Thats not an option...and i will do it myself
Old Oct 31, 2005 | 12:32 PM
xxwhixx's Avatar
well good luck man hope it works out for you
Old Oct 31, 2005 | 12:37 PM
AMECustom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxwhixx &raquo;</TD></TR><TR><TD CLASS="quote">well good luck man hope it works out for you </TD></TR></TABLE>
tHank you
Old Nov 15, 2005 | 06:22 AM
Bellydragger's Avatar
What kind of information are you looking for? When you split the cases stuff wont go flying all over, if you know what to do.
Old Nov 15, 2005 | 07:28 AM
AMECustom's Avatar
Default Re: b16 transmission rebuild...? (Bellydragger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bellydragger &raquo;</TD></TR><TR><TD CLASS="quote">What kind of information are you looking for? When you split the cases stuff wont go flying all over, if you know what to do.</TD></TR></TABLE>
Its all good, i was gonna rebuild it this winter, since i had to postpown my k-swap, but i just bought a K24a2, and im just gonna sell tEh trans as is...
Old Nov 24, 2005 | 06:28 PM
integra da's Avatar
what do u want for it
Old Nov 24, 2005 | 09:50 PM
AMECustom's Avatar
Default Re: b16 transmission rebuild...? (tsointegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsointegra &raquo;</TD></TR><TR><TD CLASS="quote">what do u want for it</TD></TR></TABLE>
well im sellin my whole b16 swap as a complete package, which includes everything. It has 38000 miles or so. I only put around 8 thousand, with the oil changed every 3. I'm lookin for 1500$ for everything, motor,trans, ecu, shift linkage, axles, JDM ITR header, high flow cat (2.5" for ITR flange).
Old Nov 25, 2005 | 04:05 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I have my old LSD B16 transmission apart too. It comes apart easilly. (the case) However, you DEFINATLY want to invest in a Helms manual for a DOHC VTEC engine. (VTEC Del Sol, 94+ Integra, 99-00 Civic Si) Its not an easy task. If you are going to attempt it, have an extremely clean work area, and be very very careful. The damn spider bearings are the worst part. The ****** fall apart everyplace if your not careful...
I would recommend replacing all of the bearings and get an LSD, if it isn't equipped.
Good luck!
Old Nov 26, 2005 | 08:47 PM
AMECustom's Avatar
Default Re: b16 transmission rebuild...? (JDM_Ej)
^^^^hey thanks JDM
TORTUGA
22
Feb 20, 2013 09:29 PM
Brandon H.
Dec 15, 2010 08:01 AM
theERAisBack
Dec 3, 2007 06:11 PM
AMECustom
31
Oct 31, 2005 04:28 AM
AMECustom
Oct 30, 2005 05:35 PM
