00 ITR Problems CEL 67?
I got a CEL 67 Catalyst system efficency below threshold. Im not sure what it is, does it have somthing to do with the charcoal canister? I dont have any evap purge codes or anything else...anyone ever have this problem before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe »</TD></TR><TR><TD CLASS="quote">so does that mean that it is clogged and needs to be replaced</TD></TR></TABLE>
No, it pretty much means it isn't working because it fell apart or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe »</TD></TR><TR><TD CLASS="quote">maybe but why wouldn't the ECU throw a code For the primary or secondary o2 sensor</TD></TR></TABLE>
1) the 1st and 2nd O2 sensor values are compared to determine catalyst "efficiency"
2) bad 1st or 2nd O2 sensors have/give different respective codes.
I know some people who have modified cars get this code ocassionally. Personally, I'll get this code occasionally on my mildly modded car. I just reset the ECU and CEL disappears for 6 months or so. I wouldn't worry about it too much unless you have terrible fuel efficency or some other noticable issue.
Ill check the o2's out, and I got this code once before on my DD Civic but i cleared it and it never came back, but yes it is creating a problem its running like garbage, I get this like gulping or hiccupping sound when i let off the throttle and i was thinking that exhaust gasses were trying to back up into the combustion chamber. thanks for the help so far
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe »</TD></TR><TR><TD CLASS="quote">Ill check the o2's out, ...</TD></TR></TABLE>
Look, take your exhaust apart and see if you can see (yes I know that might sound funny) through your cat!
