should I be happy with 307whp @230ft/tq?
Old Oct 30, 2005 | 07:43 AM
boost fed ls's Avatar
Default should I be happy with 307whp @230ft/tq?
Here is my set up
Engine: Ls/vtec
9:1 cp pistons
eagle rods
inline pro block guard
b18c1 p&p head (stock valve train)
garrett t3/t04e (57 trim 63a/r housing)
equal length mani
3inch dp
thermal 2.25inch exhaust
I made 307whp and 230ft/tq on 11psi, should I be happy with these numbers? I Was expecting a little higher numbers. Any comments welcome.
Old Oct 30, 2005 | 07:44 AM
a1320addict's Avatar
Default Re: should I be happy with 307whp @230ft/tq? (boost fed ls)
are you happy with it?
dont worry about what the h-t community thinks of your engine's output, the real question is if you are happy with it.
Old Oct 30, 2005 | 07:45 AM
shyboy817's Avatar
Those numbers are pretty average, actually pretty good. The 3" dp to 2.25 exhaust is a lot of restriction.
Old Oct 30, 2005 | 08:02 AM
Default Re: should I be happy with 307whp @230ft/tq? (yehiknowrite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">are you happy with it?
dont worry about what the h-t community thinks of your engine's output, the real question is if you are happy with it.</TD></TR></TABLE>
I am ok with it, I was expecting a little more. I was thinking around 325 or so, I was asking to see if this was expected for this kind of set up or was I just shooting a little high. I am really shooting for 400+whp but I was limited to 11psi due to injector duty cycle.
Old Oct 30, 2005 | 08:05 AM
non-VTEC's Avatar
with that exhaust system you have on there i would be happy with that power....
Old Oct 30, 2005 | 08:08 AM
blackeg's Avatar
im just finishing up my ls/vtec now using the same turbo you have. im shooting for 300/225 to 230 at 10 psi. your #'s are fine, right in the ballpark of where they should be. i would be happy, but then again when i first dyno'd my ls at 238/204 i was kinda pissed, but then i realized it was right where it should be, and thats fine.
dont be as concerned with the #'s, its all about are you happy with the way the car feels and drives.
Old Oct 30, 2005 | 08:30 AM
B18 CYA's Avatar
i made 334 whp and 242 tq on a t3/t04e 54 trim
Old Oct 30, 2005 | 08:33 AM
boosted k20's Avatar
Default Re: (B18 CYA)
those numbers seem good to me
Old Oct 30, 2005 | 09:24 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">i made 334 whp and 242 tq on a t3/t04e 54 trim</TD></TR></TABLE>
what boost level??
oh, boost fed ls- you would seriously benefit from a larger exhaust.
Old Oct 30, 2005 | 09:28 AM
B18 CYA's Avatar
ah how can i forget that, 18psi, 2.5" exhaust, i dunno they seemed low to me
Old Oct 30, 2005 | 09:45 AM
EVIL Hx Coupe's Avatar
They're decent number, and only you know if you're going to be satisfied with them.
You replaced pistons, rods, P&P head, etc to get 300whp? If it was me, I would be shooting for at least 350whp with the setup you got.
What kind of engine management are you using? Your exhaust is killing you too, try to get an upgrade ASAP and you'll see quicker spool, and better numbers.
Old Oct 30, 2005 | 09:56 AM
riceball777's Avatar
numbers looks very good for 10psi
why dont you boost more
you should be able to boost 1 bar on puump gas easy and make 350whp +
Old Oct 30, 2005 | 11:04 AM
itslogics's Avatar
Default Re: should I be happy with 307whp @230ft/tq? (riceball777)
he can't boost more because of his injector duty cycle. I would be happy with what you have.
Old Oct 30, 2005 | 11:18 AM
Archidictus's Avatar
Unceasing Measure
Default Re: should I be happy with 307whp @230ft/tq? (itslogics)
Don't expect miracle numbers with an incomplete setup. You need bigger/better duty cycle injectors to safely make more power, so go get them and post up your 400whp graph . That setup has 400whp in it, easy.
Old Oct 30, 2005 | 11:35 AM
fullblown's Avatar
we made 297 on a DD dyno at 11psi
Setup...
Ls vtec
-81.5mm bore
-b16 completely stock head
-gsr cams
-eagle rods
-3 inch exhaust
-xs t04x (dont know specs)
could of made a little more but we decided to just stop there.
Old Oct 30, 2005 | 01:03 PM
blown_LS's Avatar
Default Re: should I be happy with 307whp @230ft/tq? (fullblown)
There is nothing wrong with those numbers at that boost level...i'd get 3'' exhaust all the way back and you'd deffinetly see some nice gains from that. But as people mentioned get bigger injectors and go for more boost.
Old Oct 30, 2005 | 03:06 PM
Manny_Fresh's Avatar
Default Re: should I be happy with 307whp @230ft/tq? (blown_LS)
bump the boost a lil more and get 3' exhaust then i think u will be good
Nice numbers though
Old Oct 30, 2005 | 05:56 PM
Default Re: should I be happy with 307whp @230ft/tq? (b18c198)
Thanks for all of the replys, I need to finish my car and get it back on the dyno. I have been messing with nitrous as well. I want to run both nitrous and turbo all the time. I hooked up a friends kit on my car and on 9 psi and a 75 shot it went 12.4 at 118.8mph.
Old Oct 31, 2005 | 08:04 PM
Snail EK's Avatar
Old Oct 31, 2005 | 08:21 PM
JDM00SI's Avatar
yeah get a larger exhaust.....
Old Nov 1, 2005 | 10:04 AM
bnut510's Avatar
Default Re: (JDM00SI)
bigger injectors, more booost
nice #s
Old Nov 1, 2005 | 10:22 AM
99lspwr's Avatar
Default Re: (bnut510)
For that boost level...No doubt...
Old Nov 1, 2005 | 12:16 PM
CroteTurbo's Avatar
Default Re: (99lspwr)
I did 295whp on lsvtec 10-11 psi on .48ex .60in turbo 2.5 exhaust.
Your number look good to me.
Old Nov 1, 2005 | 12:37 PM
DaNish's Avatar
Default Re: (CroteTurbo)
get a bigger exhaust, you should make 320WHP easy at the same boost level
Old Nov 1, 2005 | 01:42 PM
vaporboy12's Avatar
Default Re: (DaNish)
each setup will differ. my 2.0l lsvtec made 356whp and 263ftq at 10psi
