Flywheel in Prelude BB3 F20a4 engine
Old Oct 30, 2005 | 07:10 AM
BB4-Japanpower's Avatar
Default Flywheel in Prelude BB3 F20a4 engine
hi
could you help me please
i have an european modell honda prelude 94 with the f20a4 engine
i cannot find a flywheel that could fit into my prelude
fidanza has only flywheels for h-series engines not for my f-series
would every flywheel for f-series fit in my prelude
thanks
pics from my cars
the white one is from my wife its a f20 prelude bb3 too
the red one is mine but the rim color ist photoshopped they are silver
the green one is a h23 BB2 but the engine is damaged
greetings from germany
Old Oct 30, 2005 | 08:10 AM
Sam1am26's Avatar
Default Re: Flywheel in Prelude BB3 F20a4 engine (Japanpower)
Any F or H series flywheel will work for you... But wow... I would love to have a 4th gen prelude with an f20a4 in it... I would just slap on an H22 head with ome huge cams and a huge turbo and rev the **** out of that thing....
Old Oct 30, 2005 | 12:05 PM
Default Re: Flywheel in Prelude BB3 F20a4 engine (Sam1am26)
thank you
but how can i install a h22 DOHC head on a f20 SOHC engine ??
flywheel:
every here in germany said that i cannot install a fidanza flywheel on my f20 engine because they are made for h-series engines
Old Oct 31, 2005 | 06:03 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japanpower &raquo;</TD></TR><TR><TD CLASS="quote">thank you
flywheel:
every here in germany said that i cannot install a fidanza flywheel on my f20 engine because they are made for h-series engines </TD></TR></TABLE>
It's a long story on the head swap... do some simple searchs for F23 block/H22 Head, or G23 VTEC... But everyone in germany is wrong, all H/F series clutches are interchangeable...
Old Oct 31, 2005 | 07:13 AM
Honda318dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">
But everyone in germany is wrong, all H/F series clutches are interchangeable...</TD></TR></TABLE>
Confirming
Old Oct 31, 2005 | 07:29 AM
Default Re: Flywheel in Prelude BB3 F20a4 engine (Honda318dx)
and the flywheels, too ??
Old Oct 31, 2005 | 07:31 AM
prelittlelude's Avatar
and the flywheel too,
tripple confirming
Old Oct 31, 2005 | 09:32 AM
Default Re: Flywheel in Prelude BB3 F20a4 engine (prelittlelude)
so i can order a fidanza and install it
can you tell where i can get it for a low price ?
who can tell me how much costs shipping to germany ??
Old Oct 31, 2005 | 03:03 PM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japanpower &raquo;</TD></TR><TR><TD CLASS="quote">and the flywheels, too ??</TD></TR></TABLE>
The H-series crankshafts have a pin that mates to a hole in the flywheel to clock the flywheel. This is so that the timing marks on it can be used. Most of the F-series engines have these marks on the accessory pulley, and their cranks/flywheels don't have the pin. In this case the flywheel can be installed in any of 8 positions (it doesn't matter). So yes, they are interchangeable, but depending on how you are mixing and matching parts you might need to drill a hole or grind off a pin. In this case, be careful about using the flywheel marks to set timing. Good luck.
Old Oct 31, 2005 | 03:06 PM
Sam1am26's Avatar
Default Re: Flywheel in Prelude BB3 F20a4 engine (flyrod)
I doubt the F20A4 even has a timing window in the block to see the flywheel... All the F blocks I have seen don't... Good info...
Old Nov 2, 2005 | 02:37 AM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">But wow... I would love to have a 4th gen prelude with an f20a4 in it... I would just slap on an H22 head with ome huge cams and a huge turbo and rev the **** out of that thing.... </TD></TR></TABLE>
Doubt it. F20A4 revs till 6500 stock. It's the same motor like in S model but less displacement. Nothing special.
Old Nov 2, 2005 | 06:07 AM
wstef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japanpower &raquo;</TD></TR><TR><TD CLASS="quote">so i can order a fidanza and install it
who can tell me how much costs shipping to germany ??</TD></TR></TABLE>
I got mine at http://www.titanmotorsports.com/ if I remember well it was something like $200 and shipping to Poland something like $50.
Old Nov 2, 2005 | 08:30 AM
Sam1am26's Avatar
Default Re: Flywheel in Prelude BB3 F20a4 engine (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">
Doubt it. F20A4 revs till 6500 stock. It's the same motor like in S model but less displacement. Nothing special.</TD></TR></TABLE>
Yeah but it it still has to have a good r/s ratio unless the pistons are rediculously small... The rods/bolts probably just aren't as beefy as an F20B...
Old Nov 2, 2005 | 09:53 AM
Default Re: Flywheel in Prelude BB3 F20a4 engine (wstef)
my f20a4 has redline at 7000 rpm
i installed
h23 intake manifold 63mm throttle
dc sports stainless steel header h23
high flow cat
invidia catback
cold air intake
and then a programmed chip just for my car that costs 450€ (nearly 580 us $)
and it runs a little bit better then a h23 and a little bit slower then a h22
Modified by Japanpower at 9:34 AM 11/3/2005
Apex1972
Jan 21, 2010 04:07 PM
h22_crx
Aug 6, 2006 12:58 PM
ams0465
Mar 15, 2004 08:53 AM
