Could I Use The Lug Nuts That I Have On My Aftermarket Wheels Right Now On Steelies?
Old Oct 30, 2005 | 04:38 AM
TegoDC5's Avatar
Default Could I Use The Lug Nuts That I Have On My Aftermarket Wheels Right Now On Steelies?
I just picked up a set of tires for cheap and I was wondering if I could use my lug nuts that I have on my aftermarket wheels on to the steelies.
Old Oct 30, 2005 | 07:39 AM
Ricey McRicerton's Avatar
Default Re: Could I Use The Lug Nuts That I Have On My Aftermarket Wheels Right Now On Steelies? (Tego)
No.
OEM lugs are acorn style. Aftermarket lugs are more of a V shape. You'll just tear up your steelies, and it's not safe.
Old Oct 30, 2005 | 09:16 AM
TurboEM1's Avatar
Default Re: Could I Use The Lug Nuts That I Have On My Aftermarket Wheels Right Now On Steelies? (Ricey McRi
what about the other way around? Can you use stock lugs on something like rotas.
riceburnerryan's Avatar
i was at les schwab and they said i need coneical *spelling* lug nuts? are those just regular aftermarket?
Old Oct 30, 2005 | 09:27 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">No.
OEM lugs are acorn style. Aftermarket lugs are more of a V shape. You'll just tear up your steelies, and it's not safe.</TD></TR></TABLE>
What bout like Muteki lug nuts?
I'm using those right now on my Si's. Should I switch to stock?
Old Oct 30, 2005 | 09:55 AM
::MYCORD::'s Avatar
Yes you should switch, they are the wrong seat type
Undercover_Skank's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
I'm using those right now on my Si's. Should I switch to stock?</TD></TR></TABLE>
nope you cant use those neither. those arent "ball seated"
Old Oct 30, 2005 | 10:11 AM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">i was at les schwab and they said i need conical *spelling* lug nuts? are those just regular aftermarket? </TD></TR></TABLE> there is a spell check button...
Old Oct 30, 2005 | 10:14 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">what about the other way around? Can you use stock lugs on something like rotas.</TD></TR></TABLE>
same question
Old Oct 30, 2005 | 10:20 AM
Padawan's Avatar
Darth ModerVader
No, you need to use the proper lug nuts for the type of wheel you are running. Rotas (like most aftermarket wheels) require a conical seat lug nut, and stock Honda nuts should <u>not</u> be used with them.
Old Oct 30, 2005 | 10:21 AM
VRD^sam's Avatar
http://www.summitracing.com
search lug nuts
Old Oct 30, 2005 | 10:38 AM
TegoDC5's Avatar
thanks guys!
boosted.CRX
Jul 13, 2006 12:45 PM
99_dc2
Feb 21, 2006 01:05 PM
.BigSexy
Feb 15, 2006 03:58 PM
cubism
Sep 13, 2004 01:17 AM
HRDCORD
Nov 30, 2003 07:04 AM
