compression test results
Old Oct 29, 2005 | 11:13 PM
bOOsTiNSoHcVtEc's Avatar
Default compression test results
#1: 155-160
#2: 175-180
#3: 175-180
#4: 120
Condition of the spark plugs were good.. not lean not rich, no detonation. What could be a list of problems I am looking at? I know for a fact the bottom end is in perfect condition so it has to be something with the head. Valve seals? Also at idle my vacuum is at 16. By the way its a b18b block with a b16 head.
Old Oct 30, 2005 | 06:02 AM
drdisco69's Avatar
Default Re: compression test results (bOOsTiNSoHcVtEc)
Check valve adjustment and for bent valves.
Old Oct 30, 2005 | 11:19 AM
Default Re: compression test results (drdisco69)
how do i check for bent valves?
Old Oct 30, 2005 | 11:49 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">how do i check for bent valves?</TD></TR></TABLE>??? how??
Old Oct 30, 2005 | 12:08 PM
Default Re: compression test results (BLUE EH3)
i mean like physically check it with the motor in the car. i know theres a trick with a dollar bill and you stick it flat up against the muffler but thats about it. what other ways are there? im hoping its the seal or seating.
Old Oct 30, 2005 | 02:45 PM
BLUE EH3's Avatar
Help we my pennies
1$......???????
Old Oct 30, 2005 | 02:56 PM
mmuller's Avatar
Mad Scientist
if a valve is bent; clearance will be way off.
Old Oct 30, 2005 | 05:22 PM
Chiovnidca's Avatar
Leakdown test?
Old Oct 30, 2005 | 08:14 PM
Default Re: compression test results (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">if a valve is bent; clearance will be way off.</TD></TR></TABLE>
I did a valve adjustment when I put the head on. The thing is I dont think I bent it.. If it is bent I think it was done by the person who owned the head b4 me. I did a valve adjustment when I put the head on. Will this method still apply? Would it be tighter or looser than spec? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Leakdown test?</TD></TR></TABLE>
Wish I had one but unfortunately I dont.
Old Oct 31, 2005 | 03:05 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote"> Would it be tighter or looser than spec? </TD></TR></TABLE>
If a valve was bent after the last time it was adjusted it should be loose.
Old Nov 1, 2005 | 02:33 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: compression test results (Chiovnidca)
one dollar?
SIK IN DA HED
Oct 6, 2017 10:47 PM
mugenboi
May 14, 2007 09:18 AM
rmoiii
May 31, 2005 10:44 AM
Carbon_Lude98
Oct 18, 2004 06:19 AM
Ryan C
Jul 25, 2003 10:13 AM
