Falken Azenis tire pressure??
Old Oct 29, 2005 | 09:58 PM
ReDHaTcHyGuy's Avatar
Default Falken Azenis tire pressure??
I just bought some polished slips off a friend an they has the recently discontinued Azenis tires...... they are 215/45/16 and i was wondering what kinda tire pressuse to run for daily driving , i saw max psi on the tire say's 51psi but u usually don' t run the max, ...........
Old Oct 30, 2005 | 07:24 AM
vietnameeh's Avatar
i would say 35-40 ALL AROUND
Old Oct 30, 2005 | 02:24 PM
Default Re: (vietnameeh)
i was thinking around that.. thanks ,, any other suggestion's?
Old Oct 31, 2005 | 03:23 AM
anybody else?
Old Oct 31, 2005 | 02:48 PM
Old Oct 31, 2005 | 10:52 PM
bump
Old Nov 1, 2005 | 08:24 AM
piotrush's Avatar
Default Re: (ReDHaTcHyGuy)
I do 38 on my prelude - steering response isnt as good as with the 205 wide so3s but overall grip is up
Old Nov 1, 2005 | 09:38 AM
civichbcx's Avatar
Default Re: Falken Azenis tire pressure?? (ReDHaTcHyGuy)
I have 205/50/15 tires on my rota slipstream rims and the guy at Tire Rack said to put them at the factory civic specs that you see on the inside of your driver's side door.
Do you guys think I should I put the PSI at higher than factory specs for daily driving? If so, Why?
Old Nov 1, 2005 | 03:13 PM
Default Re: Falken Azenis tire pressure?? (civichbcx)
with 15's ur alright but t think its different on my 16's
Old Nov 1, 2005 | 09:02 PM
piotrush's Avatar
if the tire is the same size as stock then keep the psi at stock. my stock tires were 205-50-16, with the azenis now there is just more tire on the same sized wheel, therefor I need moire pressure to fill it. Even now though if the car is parked the sidewall seems like it is sagging, even though it really isnt.
Old Nov 2, 2005 | 03:21 AM
Default Re: Falken Azenis tire pressure?? (piotrush)
well i have a 97 hatch and 16's aren't stock , i wasn't sure since its bigger and more of a performance tire
Old Nov 2, 2005 | 01:42 PM
ttt
Old Nov 2, 2005 | 04:07 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichbcx &raquo;</TD></TR><TR><TD CLASS="quote">I have 205/50/15 tires on my rota slipstream rims and the guy at Tire Rack said to put them at the factory civic specs that you see on the inside of your driver's side door.
Do you guys think I should I put the PSI at higher than factory specs for daily driving?</TD></TR></TABLE>
No. I agree with the Tire Rack. Set your pressure at the pressure recommended for your car. If you find that you need to adjust the pressure from there, based on undesirable handling and/or uneven tire wear, then by all means do so. But the pressure recommended for your car is a good place to start.
Old Nov 3, 2005 | 10:46 AM
TunerN00b's Avatar
Default Re: Falken Azenis tire pressure?? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">No. I agree with the Tire Rack. Set your pressure at the pressure recommended for your car. If you find that you need to adjust the pressure from there, based on undesirable handling and/or uneven tire wear, then by all means do so. But the pressure recommended for your car is a good place to start.</TD></TR></TABLE>
I'm running my RT-615 205/50-15s on gsr blades at 32/30 (factory recommended pressure for G3 Integra). More pressure provides better turn in (and possibly increased gas mileage), but at the expense of ride quality, and I can definately feel the ride get worse as I pump them up.
On the flip side, my stock Michelin XGT V4s wore out the shoulder with that low of a pressure, so I'll have to wait and see if the Azenis do the same.
Old Nov 3, 2005 | 11:27 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Falken Azenis tire pressure?? (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">32/30 (factory recommended pressure for G3 Integra)</TD></TR></TABLE>
The factory recommended pressure for a '94-01 Integra is 35 front, 33 rear. At least, that's what it is on my '94 GS-R as well as my '01 Type R; I don't know if it's any different on any of the other models.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">my stock Michelin XGT V4s wore out the shoulder with that low of a pressure, so I'll have to wait and see if the Azenis do the same.</TD></TR></TABLE>
When you say "shoulder", are you referring to only the outside edge of the tread, or both edges of the tread? Wearing out the outside edge is not a symptom of low tire pressure. When tire pressure is too low (underinflation), BOTH edges wear quicker than the middle of the tread (and conversely, when tire pressure is too high, the middle wears quicker than both edges). If only the outer edge wears faster, it can have any of several causes - alignment problems (sometimes but not necessarily due to a lowered suspension), track driving, etc - but it's not normally due to underinflation.
spoon063
Honda S2000
Oct 4, 2006 04:23 PM
.water
Jan 28, 2005 02:32 PM
Understeer
Apr 21, 2003 09:31 PM
B_1_8_hatch
39
Dec 8, 2002 06:36 PM
Volcom
Nov 20, 2002 07:52 AM
