timing advace
Old Oct 29, 2005 | 08:03 PM
b_serious's Avatar
Default timing advance
well.. here's the deal my timing was pretty far off when i checked the timing marks they where about an inch away from the alignment pointer.. so i set it back to where it should be using the timing light, so that i wouldnt have any CEL's but now.. the car drives like **** no throttle responce and bottom end torque is gone.. well not completly but 2nd gear last way longer then it used too.. anyone know how far is in the safe zone to move it back to where it was ? b18b 98 ls engine in a 98 ek coupe..
(cliff need to know how far to advance timing, that is safe for b18b)
Old Oct 29, 2005 | 11:30 PM
Dartanian's Avatar
Default Re: timing advance (b_serious)
You sure the timing light was hooked up correctly?
Old Oct 30, 2005 | 04:51 AM
Padawan's Avatar
Darth ModerVader
Default Re: timing advance (Das Schmoo)
It sounds as if you set the timing incorrectly. I would suggest going back and doing it again.
Old Oct 30, 2005 | 04:46 PM
b_serious's Avatar
Default Re: timing advance (Padawan)
mmm.. all i did was hook the timing light up to cyl number 1 and hooked it up to the battery.. and lined up the marks by adjusting the dizzy.. am i doing it wrong? is there anything else im missing? helpp car doesnt wanna run very well... and dies at lights somtimes.. and takes about 10 seconds to turn over to get it started
Old Oct 30, 2005 | 04:58 PM
Padawan's Avatar
Darth ModerVader
Is it a simple timing light with no adjustment dial? Are you using the correct marks on the pulley when adjusting the timing? Did you jump the service connector before trying to make the adjustment?
Old Oct 30, 2005 | 04:59 PM
b_serious's Avatar
where is the connector... i didnt do that.. is it the one near the ecu? obdII i thought didnt have it.. and im lining the pointer to the middle of the three marks on the crank pulley
Old Oct 30, 2005 | 05:05 PM
92integraVTECgsr's Avatar
have you tried resetting your ecu?? clear the old settings so it can learn the new settings??? plug the ECU fuse out for 15-20 minutes
not sure where the connector is on 94-up
Default Re: timing advance (92integraVTECgsr)
**pull the ecu fuse out
Old Oct 30, 2005 | 05:11 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious &raquo;</TD></TR><TR><TD CLASS="quote">where is the connector... i didnt do that.. is it the one near the ecu? obdII i thought didnt have it.. and im lining the pointer to the middle of the three marks on the crank pulley</TD></TR></TABLE>
Yes, the service connector is the 2-wire connector located near the ECU. You should jump it with a small wire or paper clip before attempting to adjust the timing.
Old Oct 30, 2005 | 05:13 PM
b_serious's Avatar
alright im gonna go try it ill check back in 10 min to see how it goes.. lol im gonna jump the wire and adjust it to the white mark on the pulley or in the middle of the 3 marks?
Old Oct 30, 2005 | 05:19 PM
Padawan's Avatar
Darth ModerVader
You want to adjust it to the middle of the 3 marks on the pulley. Since your idle is higher than normal, you may want to adjust it to the red mark shown on the C-Speed instructions.
Old Oct 30, 2005 | 06:13 PM
b_serious's Avatar
alright thanks alot man.. its set past the red mark just a little bit and runs perfect and no CEL anymore.. thanks!!
Old Oct 30, 2005 | 06:21 PM
Padawan's Avatar
Darth ModerVader
I'm glad everything worked out.
rhdins
Aug 25, 2008 07:26 PM
civic j
Aug 17, 2007 08:10 AM
xJDMCx
Sep 15, 2006 09:34 AM
euclid
Oct 16, 2004 09:41 PM
Propulsion
Sep 18, 2004 06:56 PM
