clicking noise while turning
Old Oct 29, 2005 | 07:09 PM
accordredliner's Avatar
* B A N N E D *
Default clicking noise while turning
It is probably my axle but what other possibilities r there? If it is my axle is there a way to find out which side is bad? i can't determine which side by listening from inside the car. Will it make the clicking sound if I turn the wheel by hand?
My boots was on the verge of splitting and i changed the boot and repacked. That was about 15k ago.
Old Oct 29, 2005 | 07:33 PM
BLKFLSH's Avatar
Default Re: clicking noise while turning (accordredliner)
Get someone to walk beside the car while slowly turning. Or get someone to drive and you walk. what ever you can get someone to do for you. It might do it if you jack it up and turn it by hand, I don't know.
https://honda-tech.com/zerothread?id=1417972
Check this link out.
Old Oct 29, 2005 | 07:38 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: clicking noise while turning (BLKFLSH)
axle
Old Oct 30, 2005 | 01:54 AM
* B A N N E D *
Could it be something else? My bearings were never exposed to the envir. I changed the boots when I saw that they're cracked.
then again 134k axles are pretty old axles
Old Oct 30, 2005 | 06:35 AM
P_Adams's Avatar
Default Re: (accordredliner)
There was a gentleman in here (just b4 New Orleans was wiped from the map) who suffered a complete CV Joint failure (wouldn't move) yet the CV Boot was intact. That was on a '98 5spd I believe.
P
Modified by P_Adams at 2:34 PM 10/31/2005
Old Oct 30, 2005 | 07:23 AM
94accordsedan's Avatar
Banned
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">There was a gentleman in here (just b4 new Orleans was wiped from the map) who suffered a complete CV Joint failure (wouldn't move) yet the CV Boot was intact. That was on a '98 5spd I believe.
P</TD></TR></TABLE>
I had the same thing happen on my 94. Get the axle replaced.
Old Oct 30, 2005 | 07:41 AM
HondaMike17's Avatar
Default Re: (94accordsedan)
theres a possibility there could be a ticking time bomb under your car that only activates when you turn and thats what your hearing, but lets go with it being your axle
Old Oct 30, 2005 | 08:38 AM
* B A N N E D *
what could happen if i keep driving it? I don't mind the clicking
Old Oct 30, 2005 | 09:11 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">what could happen if i keep driving it? I don't mind the clicking </TD></TR></TABLE>
the axle will snap and you'll miss halloween party
is the clicking noise in a constant speed?
Old Oct 30, 2005 | 09:30 PM
* B A N N E D *
a sharp turn going around 15 mph will produce the sound. It seems to vary with speed.
Can a bad upper ball joint cause clicking because my upper ball joint boot is busted.
Old Oct 30, 2005 | 09:55 PM
96Sedan's Avatar
Sounds like an axle problem
Old Oct 31, 2005 | 05:39 AM
P_Adams's Avatar
It will choose the most inopportune moment to break.
You know, several hundred miles from home in East Bumf...k somewhere, where it will cost all manner of cash (Bubba doesn't take checks and he doesn't take Visa (Voice Over)) just to get it towed home.
Get it fixed.
P
Old Oct 31, 2005 | 05:50 AM
deserthonda's Avatar
the chances of braking are slim i have only seen 4 brake in many years at the job, but they were very very noisy before they brike even on straight roads u could hear the car coming, but it will brake if let go unattented and like P-said it willl happen when u are all dressed up and going to a party or running late to gret to airport,or when u are drivind in the middle of nowhere,,,,,,,,,
Advice ??? replace it as soon as u can .......u can pick 1 up and take it to shop to install ,,autozone is only 60-70- dollars..
Old Oct 31, 2005 | 06:34 AM
Juccord's Avatar
Default Re: (deserthonda)
I have that problem right now, first it started on one side, this was when I was at about 90,000Km, then when I hit bout 115,000Km my other one went. Now im at 128,000Km and they are both clicking like never before...! I keep telling my self ill fix it when I put it away for winter..I hope they dont snap before.!
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
WhiteOnRice
14
Sep 26, 2006 10:16 AM
gospeedgo1
18
Oct 25, 2005 06:25 PM
flip1199
Oct 24, 2002 10:58 AM
B18C-RnVA
Feb 25, 2002 08:30 PM
