strut and sway bars
Old Oct 29, 2005 | 06:31 PM
Brown-tec's Avatar
Default strut and sway bars
hey whats the difference between sway bars and strut bars? if yall got pix that be most appreciated!
Old Oct 29, 2005 | 06:52 PM
ludiferino's Avatar
Default Re: strut and sway bars (Brown-tec)
Strut bars connect the strut towers (chasis) to prevetn chasis flex. Sway bars connect the motion/forces/ between the otherwise independent wheel actions. Sway bars will create a larger difference in handling than strut bars.
cliffs: strut bars are found in the trunk and under the hood; sway bars are found under the car.
Old Oct 29, 2005 | 09:03 PM
Brown-tec's Avatar
Default Re: strut and sway bars (ludiferino)
thnx i was gettin confused
Old Oct 30, 2005 | 08:40 AM
H.crx-si
Guest
Posts: n/a
Don't let tie bars confuse you either. They are located under the rear and under the front of some sports cars and are available in after market. They are a bar that joins two points on control arms to stiffen the chasis and reduce flex.
Old Oct 30, 2005 | 11:46 AM
Brown-tec's Avatar
Default Re: (H.crx-si)
yea im tihnkin bout gettin the srtut bar under the hood and a tie bar for the bottom of the car and the other strut bar for in the trunk
Old Oct 30, 2005 | 12:58 PM
ludiferino's Avatar
Default Re: (Brown-tec)
I will reiterate, the rear sway bar will make a greater handling difference than probably all three bars you are considering (struts and tie). Unfortunatly, they are not as noticable (read: flashy) to an onlooker, but I notice my sway bar everytime I get in my car.
Old Oct 30, 2005 | 06:51 PM
Brown-tec's Avatar
Default Re: (ludiferino)
thnx......somethin to consider...hmm
99ls
Oct 18, 2009 07:02 PM
ali7up
Oct 3, 2007 09:48 AM
haitian1
12
Feb 16, 2006 04:35 PM
AzN_Flava
Oct 27, 2002 08:46 PM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
