92 civic part out
i got a 92 civic cx that i am parting out. or sell as it is
motor
96 ls (88K) botom end
92 b16 head (unknown miles)(incudes intake and Distributor for plug n play install )
b16 transmission (hydro)
arp head studs (for ls\vtec)
itr cams
extra stuff for the motor
gsr vavle train (in wall-mart bag)
gsr oil pump
gsr water pump
gsr pistons and rods
gsr timing belt
original ls head, intake and Distributor
stuff for car
96 ls seats front and rear , dash , carpet,
ebay tie bars (4 piece set)
auto meter gauge pod (holds 3 gauges on pillar)
96 ls shift linkage with ebay dual bend shifter
chipped p28 with zif and burner
ebay all aluminum radiator (i think it leaks around drain ****)
short ram intake (need to be striped and repainted)
15" rota n-groups (black with red stripe)
this car is a good running car it is my daliy driver but i just got a 93 240sx
and i want to have fun with it for a while. i will consider selling the car as it sits
you can cheack out the hisroty of the car since i had it..
https://honda-tech.com/zerothread?id=1032710 it has been wreacked again since thoose pics^
i had to replace every thing under the front end so it gotl 96 ls brakes and sway bars (have sway bar for rear also just not installed)
and it needs a paint job. there are barb wire scratches all over car
motor has been run on royal purple since i have had it and changed every 3500-4000 miles
mak offer or i will trade for part for the 240sx
motor
itr cams
gsr oil pump
gsr water pump
gsr timing belt
stuff for car
