new motor is smokin!!
Just built my motor and put new piston rings and etc on. Is the motor supposed to smoke like it is? its white smoke and theres a lot sometimes and not so much other times. im hoping its just because its a new motor and it will go away.... anyone have the same experience or know whats causing it? search is down so i posted here. thanks
well..thats not to bad..if it was fromt the engine then it would or could be a faulty hose..but since its the tail pipe ur either burning carbon (which is good) or your burning some oil..if it goes on for a while i would be concerned..but if its carbon, then it should stop soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb »</TD></TR><TR><TD CLASS="quote">just remmber....
white = water
blue = oil
black carbon/fuel</TD></TR></TABLE>
Ditto, if it's white sounds like your headgasket didn't seal all the way.
white = water
blue = oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">
Ditto, if it's white sounds like your headgasket didn't seal all the way.</TD></TR></TABLE>
I was thinking the same thing
White = Water/Coolant
yea im pretty sure its white. i have about 180 miles on the motor now and its still smoking. i was lookin at the motor today and i dont know for sure but i could of put the head gasket on backwards even tho im like 99% sure i put it on right. it smokes like A LOT sometimes and not so much other times. any suggestions. its an LS/VTec set up. stock head, gsr internals on block.
Tonyl507
Oct 8, 2006 02:44 PM
