Car doesnt crank after oil change????
For some reason .. after i did an oil change on my 92 civic dx it wont crank you hear the fuel pump engauge but i cant even get it to crank.. i have a turbo timer on my keychain i think this might have something to do with it does anyone have any ideas or anything? thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luderollin »</TD></TR><TR><TD CLASS="quote">i have a turbo timer on my keychain</TD></TR></TABLE>
whaa???
whaa???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop »</TD></TR><TR><TD CLASS="quote">whaa???</TD></TR></TABLE>
i second that!!
i second that!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxborist »</TD></TR><TR><TD CLASS="quote">
i second that!!</TD></TR></TABLE>
i third that
i third that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hecdosage »</TD></TR><TR><TD CLASS="quote">Check your fuel pressure, If thats good check compression if thats good check your spark. Then get back to us.</TD></TR></TABLE>He said it doesn't crank. That sounds more like a starter problem.
Getting battery voltage at the starter signal wire?
Good connections from battery to starter (big wire)?
Hit the starter with something while trying. If that works, your starter's bad.
