can a 94ex ecu be reprogramed to run a 95 gsr motor?
Old Mar 7, 2002 | 09:29 PM
92 CiViC gsR's Avatar
Default can a 94ex ecu be reprogramed to run a 95 gsr motor?
are all the pins on the connectors and ecu the same for the functions that they are suppose to ruN? n how much should it cost me to have the ecu reprogramed?
Old Mar 7, 2002 | 09:38 PM
HXMan's Avatar
Default Re: can a 94ex ecu be reprogramed to run a 95 gsr motor? (92 CiViC gsR)
Yes, but you will lose your secondaries.
Old Mar 7, 2002 | 10:46 PM
TurboBumblBee's Avatar
Default Re: can a 94ex ecu be reprogramed to run a 95 gsr motor? (HXMan)
nothing is wrong w/ losing secondaries.. you also look them w/ a skunk2 or ITR intake manifold..
Old Mar 8, 2002 | 01:57 PM
Stop the Beast's Avatar
Default Re: can a 94ex ecu be reprogramed to run a 95 gsr motor? (95CivicEX)
Don't run it unless you are going to use a single butterfly intake manifold. The loss of the secondarys will hurt your low-end on a stock b18c1 because of too much airflow with the runners always open. I'm going to use a P28 ECU on my B18C1 with a Skunk2 I.M. it's been programed already and it was tested in a donor car and ran great. I paid $190 from Locash Joe Sawyer @ Hasport. It would have been $150 but I had him customize it a bit.
Old Mar 8, 2002 | 02:18 PM
Thrashin's Avatar
Default Re: can a 94ex ecu be reprogramed to run a 95 gsr motor? (brokstar)
i have a skunk p28 ecu in my car with the skunk intake manifold. it works great, you can use the p28 with the stock gsr manifold but i wouldnt recomend it, like brokstar said your car will not run as it should. if you use the p28 then you should definatly get the skunk 2 manifold. also the type r manifold will not work because the bolt pattern is different.
xplanetearth420x
Apr 22, 2004 09:28 PM
deftones0817
Feb 14, 2004 11:16 AM
envious1320
17
Nov 20, 2003 11:50 AM
TeamTooQuick
Jun 2, 2003 12:18 AM
