55 Shot on 00 Si?
i dont know if you gotta upgrade internals for a FI/nitrous mix. ( i would personally do it) but make sure you got some one to tune it out for you......
you can do a lot of things to your ride if you tune it correctly.....IMO
you can do it. there was a kid on this board using a jrsc and 50 shot on a sohc. it hung together. I would recomend anything more thatn the stock pulley(6psi) and the 50 shot. becarefull, remember running both of those you have twice the chance of leaning out so be carfull!!
It only shoot juice when the pedal is at wide open throttle (so you dont bust your block to pieces).
if you want to do that without upgrading your internals, upgrade your fuel system and keep your boost relatively low. those things get hot FAST.
