JDM GSR motor?
Old Oct 29, 2005 | 10:05 AM
JDMJunior's Avatar
Default JDM GSR motor?
yea i'd like to know if theres a difference between a JDM gsr motor and a usdm gsr motor.would it be a good swap for a 92 civic hatch Si or is the b16 better.
Old Oct 29, 2005 | 10:06 AM
underb00steg6's Avatar
Default Re: JDM GSR motor? (JDMJunior)
b16 is not better , the gsr has mor torque and will make more torque with upgrades....gsr is way better
Old Oct 29, 2005 | 10:07 AM
robbie_R(eg6)'s Avatar
well the gsr has a lot more power and torque than the 16, and would definately be a good swap into an eg, but im not sure wat the differences are between the j spec and us spec, but i think the j has more power not sure
Old Oct 29, 2005 | 10:10 AM
jdm gsr has a little bit higher compression than the usdm gsr ......and i believe that's the only difference. not 100% sure tho.
Old Oct 29, 2005 | 10:17 AM
mx621's Avatar
Default Re: JDM GSR motor? (underb00steg6)
comp is 10.4:1 jdm, 10:1 usdm. hp is 180 jdm, 170 usdm, and a hare higher torque, like 3-4 lb-ft on jdm. in my opinion gsr is best bang for ya buck. better than a sweet 16, and a whole lot less than a type r swap. it fits right in the middle.
Old Oct 29, 2005 | 10:18 AM
mx621's Avatar
Default Re: JDM GSR motor? (mx621)
i ment to say 10.1:1 on usdm
Old Oct 29, 2005 | 10:33 AM
JDMJunior's Avatar
thnx for the comments i think the jdm gsr motor is the one for me
Old Oct 29, 2005 | 11:28 AM
CHiNkStEr's Avatar
some jdm gsr motors have LSD also.
Old Oct 29, 2005 | 11:32 AM
bahraini civic's Avatar
Default Re: (*****StEr)
a b16 head on the b18 is a great idea too ..........
Old Oct 29, 2005 | 11:45 AM
Makdaddynuge's Avatar
i got jdm gsr motor with jdm 4.7 fd type r tranny. Best power band, so fun to drive.
Old Oct 29, 2005 | 01:54 PM
JeffBro's Avatar
I am fairly sure the jdm gsr has 10.6 C/R and the USDM has 10 C/R. 180 vs 170hp and a few more torque. They also may have an optional LSD from the factory. I happen to have a b18c with an LSD and its a nice motor. It would smoke in a hatch. Plus the obd1 jdm gsr isnt too bad to ref either.
Old Oct 29, 2005 | 05:07 PM
MikeEM1's Avatar
Default Re: JDM GSR motor? (JeffBro)
b18c gsr motor is way better, especially if you decide to boost.
Old Oct 29, 2005 | 06:12 PM
Reedy's Avatar
Ive got the jdm b18c in my 94 ex, best $3500 I ever spent! The car became a blast to drive and with a little nitrous you can dust most stock V8's
Old Oct 29, 2005 | 06:38 PM
HabitualOffender's Avatar
Default Re: (Reedy)
Well, as long as money is not an object, swap in the more expensive option. Hell, it ain't my money. BUT... you can still make a B16 a fun swap. With the money you'd save you could do other modifications.
Old Oct 29, 2005 | 06:55 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">b16 is not better , the gsr has mor torque and will make more torque with upgrades....gsr is way better </TD></TR></TABLE>
Old Oct 29, 2005 | 07:04 PM
newtothis's Avatar
Just to elaborate...
http://www.streettuners.com/cu...tegra
97-98 Gsr B18C1 3G - DC 1797 10.0 : 1 170 @
7600 rpm 128 lb/ft @
6200 rpm USA
95-97 Si R B18C 3G - DC 1797 10.6 : 1 178 @
7600 rpm 129 lb/ft @
6200 rpm Japan
Old Oct 29, 2005 | 07:08 PM
JDM-EJ1's Avatar
Default Re: (newtothis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newtothis &raquo;</TD></TR><TR><TD CLASS="quote">Just to elaborate...
6200 rpm USA
6200 rpm Japan </TD></TR></TABLE>
It hasn't actually been proven that a JDM motor is faster than a USDM motor. Only motors that are brand new will have those numbers. Obviously the JDM motors we buy have anywhere from 20k-40k miles on them, while a USDM could have the same.
We'd have to get a dynochart with both motors to actually prove this.
Old Oct 29, 2005 | 08:24 PM
newtothis's Avatar
I just put that there so he could get an idea. But, if those numbers are produced when new, and after 40k both motors are tested, why should the numbers be different, well, not the numbers, but the difference. They may drop I'm sure, but both should drop the same is my guess...but what do I know..
Old Oct 29, 2005 | 08:26 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newtothis &raquo;</TD></TR><TR><TD CLASS="quote">I just put that there so he could get an idea. But, if those numbers are produced when new, and after 40k both motors are tested, why should the numbers be different, well, not the numbers, but the difference. They may drop I'm sure, but both should drop the same is my guess...but what do I know.. </TD></TR></TABLE>
This could be true. It depends on how the motors are treated, I'm guessing.
delsoldr1vr
Jul 11, 2012 12:15 AM
NOOdS
107
Apr 7, 2009 07:32 PM
RuffGsR
Jun 24, 2003 05:29 PM
xcivic_ex
May 30, 2003 09:36 PM
hotintegranights
Dec 21, 2002 05:20 PM
