Refinishing wheels: Can I use paint thinner?
Old Oct 29, 2005 | 04:41 AM
SRd240sx's Avatar
Default Refinishing wheels: Can I use paint thinner?
Ok guys I have a pair of SSR Formula Mesh that I want to refinish. The face has dirt stuck in between spokes and it's almost impossible to clean (haven't really tried to scrub that hard though). I was wondering if I could just remove the face and soak it in paint thinner for a few hours and then wash everything off?
I've used paint stripper/aircraft remover before on wheels, and it didn't turn out pretty. Maybe I didn't have enough but the clear coat/paint would come off blotchy and I couldn't exactly get EVERYTHING off. I dunno maybe I'm just a noob.
Any insight is appreciated. I would like to know the best way to refinish these. I plan on removing everything (paint, clear) and then spraying it black.
On my other Rota rims I just sanded the spokes down and sprayed it, but that would take ALOT of elbow grease since there are 1,000 spokes on these damn rims... It'd take forever to finish.... Any ideas?
These aren't mine... mine are a lot dirtier. Just for reference. TIA
Old Oct 29, 2005 | 04:42 AM
SRd240sx's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (SRd240sx)
Or how bout bead/sandblast?
Old Oct 29, 2005 | 06:17 AM
JDMrps13's Avatar
i would sand blast them just because its easier and you get better results.....i used aircraft remover on my stock s13 wheels.....i mean it worked but took forever.....i have access to a sand blaster so....it just makes life a lot easier......so u drive a 240 huh...got any pics......
Old Oct 29, 2005 | 11:57 AM
SRd240sx's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (JDMrps13)
Hey thanks for the reply.. yeah got a 240, don't have any good pics at the moment, but planning to take some next week
What places usually have a sand blaster? Typically how much is labor per wheel?
Old Oct 29, 2005 | 12:48 PM
SRd240sx's Avatar
reason why i say paint thinner is because it's really cheap and i can just soak the face in it..
just don't know if paint thinner will really take anything off
Old Oct 29, 2005 | 06:03 PM
UncleD's Avatar
If the wheels have a clear coat over them I wouldn't even bother with paint thinner. Also I would not recommend sand blasting it either. Aluminum is soft and the sand can actually pit the aluminum, and in some cases making it weaker. I would suggest having them chemically dipped. It strips EVERYTHING, clear coat, dirt/tar, and paint. That is your best option and doesn't cost much to do. Good luck
Old Oct 29, 2005 | 06:07 PM
UncleD's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (clean rice)
Example of my MR5's before and after being chemically dipped....
And now they look like this....
check sig
Old Oct 29, 2005 | 10:54 PM
SRd240sx's Avatar
looks awesome, can you provide more info on chemical dipping?
Old Oct 30, 2005 | 09:02 AM
Royal_C!ty's Avatar
Damn, those MR5's came out righteous
Old Oct 30, 2005 | 10:36 AM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRd240sx &raquo;</TD></TR><TR><TD CLASS="quote">looks awesome, can you provide more info on chemical dipping?</TD></TR></TABLE>
Umm, I'm not really sure exactly what the chemicals are that are used. I know it doesn't weaken the aluminum or anything. Any local bead blasting/sand blasting place should offer it, and it only takes a few minutes to do. I got mine back the same day.
Old Oct 30, 2005 | 02:16 PM
SRd240sx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">
Umm, I'm not really sure exactly what the chemicals are that are used. I know it doesn't weaken the aluminum or anything. Any local bead blasting/sand blasting place should offer it, and it only takes a few minutes to do. I got mine back the same day.</TD></TR></TABLE>
thanks for the info. how much did it cost?
Old Oct 30, 2005 | 06:03 PM
UncleD's Avatar
It was like $20 a face or somethin like that.
Old Oct 30, 2005 | 06:19 PM
SRd240sx's Avatar
wow not bad, i'll look into it, thanks alot clean rice
Old Oct 30, 2005 | 06:30 PM
UncleD's Avatar
No problem, good luck man
btraut
Sep 10, 2012 04:37 PM
WhiteGSR95
Paint and Body
Apr 7, 2012 07:01 PM
NuHon_2001 Accord
Jul 20, 2008 07:48 PM
biggishjay
Sep 18, 2007 05:41 AM
SingleCamIam
Jun 23, 2005 08:53 AM
