Ek front sway bar and lower control arms.
Alright, first off I have a 99 hatch with gsr front and rear brake setups. I already have a rear sway bar setup on the car with omni rear lower control arms. What I am looking to do is get the front sway bar on the car but there is no mounting points on the front lower control arms for the sway bar end links. Which would be the better lower front lower control arms to go with? I am thinking that the 99-00 EX and SI front lower control arms would be the same but it shows to have 2 different styles of sway bar end links and thus having two different mounting solutions.
Someone help me out with some suggestions or let me know what you are running since the search feature doesnt seem to be working right now.
As for the front sway bar that i'm wanting to install, it's from a 99 gsr.
--Justin
--Justin
yeah i have a 99 dx hb and im tryin to put some front suspension techniques on but im having the same prob, im thinkin im going to have to go the junk yard and pick up some si lower control arms thats all i could suggest to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slosc2 »</TD></TR><TR><TD CLASS="quote">EX or SI frotn lca's will solve your problem</TD></TR></TABLE>
If you get the Si's you'll also need the shock forks as well.
bakomack
Aug 8, 2009 03:14 PM
dc2leftovers
Jul 24, 2009 12:27 PM
Tuner Eddy
13
Dec 22, 2007 06:01 AM
