Suspension & Brakes Theory, alignment, spring rates....
Will it lower???
Old Oct 28, 2005 | 11:18 PM
epraion62's Avatar
Default Will it lower???
If I put like koni yellow or other shocks on my civic, would it lower it like about 1/2 an inch? I only got lowering springs on them and I only want the front drop about a half inch more...
Old Oct 29, 2005 | 03:26 PM
92bubblesi's Avatar
Default Re: Will it lower??? (epraion62)
No. You need to get coilovers, different springs, or a fat girlfriend to ride along with you.
Old Oct 31, 2005 | 06:08 AM
verycleanhatch's Avatar
There are koni shocks where you can adjust the place where the spring sits(lower or higher). It is called sp3 koni's. Correct me if i am wrong.
Old Oct 31, 2005 | 06:35 AM
nonsense's Avatar
Default Re: Will it lower??? (nomorehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomorehatch &raquo;</TD></TR><TR><TD CLASS="quote">There are koni shocks where you can adjust the place where the spring sits(lower or higher). It is called sp3 koni's. Correct me if i am wrong.</TD></TR></TABLE>
you're wrong.... ok well you're sorta right. All koni Sport (ie yellow) shocks come with perch adjustments for stock, lower than stock and higher than stock. The standard Koni yellow shocks have 3 options (middle is stock). There are some labled SP3 that were made for Neuspeed. They are basically the same but they have 5 positions. The middle, highest and lowest are the same as the standard Koni, but they have 1 extra step between.
To answer the original question. With Koni's you could lower it some more, but it's not really recommended if you already have lowering springs on them. I did it witha set of Eibach pro-kits and it was fine, but you have to be careful about bottoming out the shock.
Old Oct 31, 2005 | 07:51 PM
epraion62's Avatar
Default Re: Will it lower??? (nonsense)
i was just planning on replacing the front cause i'm already satisfied with the rear. so its really not recommended to replace the shocks? thanks for the replies.
Old Nov 1, 2005 | 02:38 AM
L8apex's Avatar
What lowering springs did you get btw? No, shocks don't control the ride height of the car, just how fast/slow it achieves the ride height determined by the spring (don't flame, generalizing here). I like the fat girlfriend idea. A K20 might also drop the front end a 1/2 inch.
Old Nov 4, 2005 | 10:56 PM
epraion62's Avatar
Default Re: Will it lower??? (L8apex)
I just got sprint lowering springs... i dont know... just might save up for gc/koni... thanks for the info...
2ToneEM1
20
Nov 26, 2007 03:08 PM
redDAinteg
Oct 14, 2005 08:10 PM
hybrid901
Honda S2000
Jul 10, 2004 02:24 AM
redacura
Aug 25, 2003 11:01 PM
2fast
Feb 12, 2002 09:32 PM
