Prelude H22a swap into Inte-G
Old Mar 7, 2002 | 08:23 PM
pasquagen's Avatar
Default Prelude H22a swap into Inte-G
Sup all? I tried doing a search for a prelude engine to a 94-01 integra but can't find any info. So anybody know if this is too complicated to do or what? Does anyone know how much a whole swap including labor, and everything else needed would cost? I just wanna get a picture on how much money i would need to do this and if its worth it. Well thanx all, and ya'll been really helpful.
Old Mar 7, 2002 | 08:48 PM
quikrpm'z's Avatar
Default Re: Prelude H22a swap into Inte-G (pasquagen)
id guess 1700 to 2200 for the swap alone, that includes the hasport kit.
Old Mar 7, 2002 | 11:26 PM
rodimus's Avatar
the things that will suck are the fact that you cannot keep A/C ...
summers will SUCK ...and for power steering you'll have to find
someone or a shop that can custom weld somethin to keep it..
do a search man..before i got my GSR, which was just last tuesday,
i was lookin into this swap. try h22 integra or something...
[Modified by EVOL, 12:27 AM 3/8/2002]
Old Mar 7, 2002 | 11:27 PM
threatcon13's Avatar
New User
Default Re: Prelude H22a swap into Inte-G (quikrpm)
the total swap should be around the 4.5 k range,including motor.
Old Mar 8, 2002 | 08:29 AM
StockTeg's Avatar
Default Re: Prelude H22a swap into Inte-G (EVOL)
You can keep a/c and for the p/s, you need the Prelude high pressure power steering hose.
Old Mar 8, 2002 | 09:37 PM
pasquagen's Avatar
Default Re: Prelude H22a swap into Inte-G (StockTeg)
Wait, is there a difference between H22a and H22? So whats the engine code for a prelude SH and an average prelude? Help me out guys. THanx
Old Mar 9, 2002 | 05:49 AM
Some Gook with a DC2's Avatar
jisatsu in houston does the swap for around 2300 if you already have a motor, but it costs like 4-5gz to get the whole thing done by them if they need to order a motor. if you were going to do the wap i recommend jisatsu. they specialize in ls/vtec and prelude swaps. if you go to their shop, every damn accord has a h22 in it and most civics and integra run ls/vtec and theres acouple of h22 integras.
Old Mar 9, 2002 | 09:22 AM
fiebru1119's Avatar
h22 and h22a are tha same thing.. the SH has the same engine as the baseline but different tranny (i think some kinda lsd, im not sure- and thats what makes it heavier besides the other options), the 4th gen prelude is denoted as h22a1..2,3 (?) and fifth gen 'ludes are h22a4..5(?) the 5th gen makes a little more power than the fourth gen, i wanted to get a prelude before i got my gsr so i did some reasearch on them. they dont respond as well to modification (relatively speaking) to say a b18c or b16, but even with a heavy chasis, they can pull high 14's with i/e
Old Mar 9, 2002 | 10:06 AM
redteg1's Avatar
Default Re: Prelude H22a swap into Inte-G (fiebru1119)
i don't see the point of this....the b18c is a good enough platform to work with in the first place on an integra....it def. puts out enough power to work with in the first place...if u wanted an h22 why didn't u just get a prelude or swap it into a hatchback instead of an integra. with the money u spend on swapping an h22 into an integra u could spend that money towards something else for the b18c like a turbo w/built bottom end and be much faster than after ur done the motor swap
Old Mar 9, 2002 | 12:43 PM
1 2 NV's Avatar
the lude high pressure PS hose goes to a different location than the civic for feeding the R&P. so it dont work that easy. lude/accord PS line goes under the rack and connects at the bottom of the rack. civic/integ routes over the rack and connects in the back. big difference.
94_prelude
Jul 13, 2009 10:37 AM
Oyrein
Apr 6, 2006 08:50 AM
OzWolfbane
Feb 12, 2005 08:23 PM
Digitalcivic
Oct 10, 2002 11:35 AM
Nebula
Jan 14, 2002 03:28 PM
