Help!!!
I recently replaced the steering column and while routing the ignition through the column it sparked against the metal and blew a fuse somewhere...exept all the fuses under the hood and all the fuses under the dash are fine, is there any other fuses or how do i fix this? the dome light coems on, the ignition makes the classic beep beep beep noise, but the radio doesnt come on or anything that runs off ignition. any help is appriciated
