4th gen JDM door/window visors install help...
Old Oct 28, 2005 | 06:38 PM
CleanLude's Avatar
Default 4th gen JDM door/window visors install help...
sup guys...i was able to get a used set of jdm door visors in decent condition...anyways, they did not come with installation instructions...anyone have a set of their 92-96 that can shine some light on this for me...i already bought some 3M automotive double-sided tape, but it doenst look like i will need it since there are mounting points...any info would he great...thanks
Old Oct 28, 2005 | 07:19 PM
StTook's Avatar
Default Re: 4th gen JDM door/window visors install help... (CleanLude)
Any pics? I'm curious as to what they look like - thanks
Old Oct 28, 2005 | 09:28 PM
CleanLude's Avatar
i borrowed this pic from someone...the pic here is for a DC2 integra....but the prelude visor looks very similar...
Old Oct 29, 2005 | 06:38 PM
skinnyboy's Avatar
If you havent already installed them, here goes:
On each visor there should be 6 brackets (i think) each bracket has a tiny countersunk screw on the top of the bracket.
Now wind your window down, and peel back the outer door seal, and peel down the inner seal, to expose the door frame. The seal if never touched before, will be stiff as anything, spray some WD-40 inder the seal and use a wide spatula or paint scraper to lift the seal from the frame.
On the top of the door frame you should see 5 or 6 counter sunk holes that correspond to the brackets on the visor.
Offer up the visors from below and line up the brackets with the holes. You'll need to offer them up from below at and angle and then pop them into place. You'll see how they line up and just pop them in.
The tiny screws are aluminium, so becareful not to lose them as they wont stick to a magnetized-tip screwdriver.
Replace seals and voila! JDM-ness acheived.
Note: If they are all dull, before you install them, get some light cutting compound and with an orbital buffer give them a buff and polish, mine where skanky as so i gave them a quick buzz with orby and they came up mint! I cleaned the inside of each visor with a prepwash wipe then Mr Sheened them for added sparkle.
Old Oct 29, 2005 | 09:09 PM
CleanLude's Avatar
^^thanks!!! ur da man...wut exactly did u use to shine em up??? mine are pretty dull too...
weatherall123
15
Jan 16, 2019 02:58 PM
Sinner
Feb 2, 2006 06:30 PM
odishaw
Jan 31, 2006 10:33 PM
CleanLude
Nov 27, 2005 03:55 PM
rudeS2k
Mar 14, 2004 09:34 PM
