Aligning headlight bulbs
Old Oct 28, 2005 | 03:45 PM
OogalyDoogaly's Avatar
Default Aligning headlight bulbs
This is probably nubbish, but how do I align my bulbs up/down? Do I have to play around with this screw/wheel thing. Also if I do, the screw is stripped (not from me) so any other ways? Thanks
This is pic behind the housing, uh I'm new to uploading images, lets see if I did it right. It's a 00 si by the way
Modified by OogalyDoogaly at 5:10 PM 10/28/2005
Modified by OogalyDoogaly at 8:26 PM 10/28/2005
Old Oct 28, 2005 | 04:55 PM
Ninety5Ex's Avatar
Default Re: Aligning headlight bulbs (OogalyDoogaly)
You adjsut it from the gear on the left corner of the picture. You use a phillips screwdriver from the top. Hope you understand what I'm saying.
Old Oct 28, 2005 | 05:10 PM
Default Re: Aligning headlight bulbs (Ninety5Ex)
So use the screwdriver on the smaller gear?
Old Oct 28, 2005 | 05:17 PM
o5mar1's Avatar
park15 feet in front of a wall just align both headlights to match each other
Old Oct 28, 2005 | 05:22 PM
Default Re: (o5mar1)
hm, ok, seems the screw is stripped, any ideas?
Modified by OogalyDoogaly at 8:27 PM 10/28/2005
Old Oct 29, 2005 | 10:27 AM
Ninety5Ex's Avatar
Default Re: (OogalyDoogaly)
put the screwdiver there
Old Oct 29, 2005 | 12:48 PM
Default Re: (Ninety5Ex)
Hm, I just went to try to adjust and by turnign that gear, it seems the bulb is turned left/right instead of up/down
Modified by OogalyDoogaly at 4:26 PM 10/29/2005
Old Oct 29, 2005 | 03:28 PM
Anyone?
Old Oct 29, 2005 | 05:21 PM
EvilPinkEye's Avatar
isnt there another one at the other end of the head light...check there
Old Oct 29, 2005 | 07:43 PM
Default Re: (EvilPinkEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye &raquo;</TD></TR><TR><TD CLASS="quote">isnt there another one at the other end of the head light...check there</TD></TR></TABLE>
Ah I see, ok I found the gears for vertically aligning it, thanks...Now the problem is reaching it
NOFX
17
Oct 11, 2008 04:25 PM
xthekidx
Apr 23, 2007 02:32 PM
Unjockable
Sep 23, 2001 06:03 AM
