Weird spot for a transmission to leak???
Old Oct 28, 2005 | 02:39 PM
JDM H23A's Avatar
Default Weird spot for a transmission to leak???
I have an H22A EG. The transmission consists of an ACT clutch, ACT ProLite flywheel, and Quaife LSD. Check out the picture to see where it's leaking from. That hole is filled with fluid. I stuck the end of a paperclip in the hole and it goes in about 2 inches and then stops. WTF
Old Oct 29, 2005 | 08:00 AM
JDM H23A's Avatar
Default Re: Weird spot for a transmission to leak??? (JDM H23A)
TTT
Old Oct 29, 2005 | 10:55 AM
BB6racer's Avatar
so plug it. find a bolt that will fit, as long as your tranny is shifting fine and your engine is running ok.
Old Oct 29, 2005 | 11:58 AM
JDM H23A's Avatar
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">so plug it. find a bolt that will fit, as long as your tranny is shifting fine and your engine is running ok.</TD></TR></TABLE>
The hole isn't threaded...
Old Oct 29, 2005 | 12:04 PM
vtec_lude's Avatar
it's not a hole at if i remember correctly. if there is fluid in there then it's probably jus got there from somewhere and isnt actually leaking.
Old Oct 29, 2005 | 02:30 PM
JDM H23A's Avatar
Default Re: (vtec_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude &raquo;</TD></TR><TR><TD CLASS="quote">it's not a hole at if i remember correctly. if there is fluid in there then it's probably jus got there from somewhere and isnt actually leaking. </TD></TR></TABLE>
That's what I was thinking too, but I was worried that the housing might be fuc*ed?
KayTran
Aug 3, 2008 08:41 PM
Damon Reeves
Apr 15, 2007 09:11 AM
nubs
Dec 15, 2004 02:14 PM
Ants
Mar 18, 2004 06:27 PM
OTT
Mar 8, 2004 10:38 AM
