no ABS??
Old Oct 28, 2005 | 02:05 PM
eg6_rick's Avatar
Default no ABS??
okay, so i searched and the search function was temp. out of service, so i need your help here.
I drive a 93' Accord EX 4door with ABS and four wheel disk brake. I recently (~2-3 weeks ago) replaced the two front rotors with new ones and new brake pads as well. Found out that the caliper piston on the driver's side was shot and the bearings on the passenger was shot, so i replaced that caliper and also replaced the bearings, and bleed the brakes.
Now whenever i drive and brake at a stop, it feels very very spongy, i have to keep my foot on the brake pedal for a while and is fairly close to the floor until the car comes to a complete stop. The ABS light in the dash does not come on for warning or anything. Anyone have a clue as to why my ABS is out?? and not functioning as it did before i replaced the brakes? any advice?
Old Oct 28, 2005 | 03:17 PM
deserthonda's Avatar
Default Re: no ABS?? (eg6_rick)
i would re-bleed brake system again, use a power bleeder if u can... if no air in system, might be a brake master cylinder going bad on you........
B20Zer
Suspension & Brakes
Apr 13, 2018 11:20 AM
NOTUNINGNONADA
Feb 1, 2011 07:48 AM
theineffable
Honda Civic (2001 - 2005)
Dec 17, 2010 05:57 AM
monkey508
Jun 29, 2008 12:45 PM
