Oil Pressure Gauge - Line from back of block straight to gauge in pod? Correct?
Old Oct 28, 2005 | 01:58 PM
W O T's Avatar
Default Oil Pressure Gauge - Line from back of block straight to gauge in pod? Correct?
Ive got a generic oil pressure gauge. Ive also got a T on the my block with 2 exits before the oil sensor, one is for my turbo feed and I want to use the other to run from the T to the back of the gauge by clamping it on
Is this how they are run?
Just a simple question I guess
Old Oct 28, 2005 | 03:01 PM
rainforest's Avatar
Default Re: Oil Pressure Gauge - Line from back of block straight to gauge in pod? Correct? (W O T)
yeah but i wouldent run the tee directly to the block if you have all that weight on the tee,there is a possibility the tee will break in the block and you would lose oil pressure possibly taking out bearings or worse if not lucky. ive seen this happen before on a ls vtec turbo suing the tee to the pressure sender port. try to run the tee to the firewall and run a steel-braided hose to the tee from the sender port. its a little more expensive but it is worth the peice of mind imo.
Old Oct 28, 2005 | 05:12 PM
W O T's Avatar
But it is alright to run straight from the T on the back of the block sensor to the sensor?
Old Oct 28, 2005 | 05:29 PM
rainforest's Avatar
yes
Built4Battle
Nov 2, 2011 11:39 AM
danny_civic97
Mar 12, 2007 01:00 PM
2khb
Apr 22, 2005 03:55 AM
doublejz
Jan 3, 2004 03:15 PM
luti
Jul 21, 2003 05:15 PM
