16 psi?
Don't want to sound like a jerk, but based on how you phrased that question it sounds like you have a lot of research to do. Do some searches in the prelude & boost forum.
Also let us know what you're boosting (H22, H23, F22?). Is the block built, if it isn't it's not going to take 16 psi. It really sounds like your fairly novice when it comes to boost & I would suggest finding someone or a shop that knows what they're doing to hook it up for you. To boost 16 psi you definitely need engine management, no FMU crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">i dont have many shops around...........i live in northern ohio? how much money would this cost?</TD></TR></TABLE>
I have your answer. Save up $10,000 and buy Lildrgn's motor and turbo setup from his Prelude. Then you can run 16psi, or whatever else you like.
Other than that, I'd have to say you don't appear know enough about Prelude's to even begin a motor build that would handle that type of power.
Read them all, front to back, top to bottom... come back in four days when you're done:
https://honda-tech.com/zerothread?id=689805
boostedcivicsir
May 2, 2006 08:20 AM
TegChamp
Mar 17, 2003 12:15 PM
