Cams: Which would you prefer for N/A setup?
Old Oct 28, 2005 | 11:16 AM
K-Spec's Avatar
Default Cams: Which would you prefer for N/A setup?
Skunk2, Crower, JUN, Type S, or other?
Old Oct 28, 2005 | 11:19 AM
K-Spec's Avatar
Default Re: Cams: Which would you prefer for N/A setup? (khalal538)
Oh, I forgot to mention, the cams will be used with Type S oversized pistons...
Old Oct 28, 2005 | 11:25 AM
JG Luder's Avatar
You need more than just pistons to pick a cam profile.
Search around, you'll find some nice information.
Old Oct 28, 2005 | 11:30 AM
The Weather Man's Avatar
Skunk2.........thats just my opinion though.
I've seen numerous dynos with those, and I like the numbers. I also like the quality of the cams. The lift/duration are great.
Old Oct 28, 2005 | 12:03 PM
BDRphaSe2's Avatar
depends on car, if its a daily driver no better then oem, and since its h22a go with the type s OEM cams best overall for daily driving and racing on streets , when it comes to cams i like the OEM type S and there made for the motor so in my eyes their more reliabe then aftermarket
Old Oct 28, 2005 | 01:10 PM
JG Luder's Avatar
Default Re: (BDRphaSe2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDRphaSe2 &raquo;</TD></TR><TR><TD CLASS="quote">depends on car, if its a daily driver no better then oem, and since its h22a go with the type s OEM cams best overall for daily driving and racing on streets , when it comes to cams i like the OEM type S and there made for the motor so in my eyes their more reliabe then aftermarket</TD></TR></TABLE>
You won't find many experienced Prelude guys that like Type S cams unless it's in a Type S motor.
Old Oct 28, 2005 | 03:01 PM
flyrod's Avatar
Default Re: (JG Luder)
Crower 2's work well.
Old Oct 29, 2005 | 04:42 PM
93h22a1vtec's Avatar
i had crower 3s for 63 miles before my motor blew up due to clearance issues, but they were great. And i was usin stock usdm 10:1 pistons. Im using htem agian in my all motor build, but im goin with some weisco 11.5:1 (89mm big bore, hell yea).
Old Oct 29, 2005 | 05:02 PM
machine4321's Avatar
what clearance issuse did you have
valve to piston or valve to valve
Old Oct 29, 2005 | 05:13 PM
Default Re: (machine4321)
valve to piston, the valves were hittin on the edge of the notches
Old Oct 29, 2005 | 05:25 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2, Crower, JUN, Type S, or other?</TD></TR></TABLE>
type s &lt; crower = skunk2 &lt; JUN
its all on hp basis....not preference...that ^^ will tell you what kinda power range youre looking at....
Old Oct 29, 2005 | 11:01 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Cams: Which would you prefer for N/A setup? (mgags7)
From my understanding skunk2's are about as good as JUN HP wise but are inconsistent. One person may get great results while another may not.
Old Oct 29, 2005 | 11:08 PM
vinuneuro's Avatar
Default Re: Cams: Which would you prefer for N/A setup? (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">From my understanding skunk2's are about as good as JUN HP wise but are inconsistent. One person may get great results while another may not.</TD></TR></TABLE>
Yea, but the Skunk2's aren't as full in the midrage as the JUN's and you are right, the Skumk2's aren't as consistent. I think everyone agrees that the JUN's are a quality product.
Old Oct 29, 2005 | 11:50 PM
The_Head's Avatar
I'm going with Crower, but only because I had a Crower valvetrain already. Kind of iffy about mixing different valvetrains and cams.
Old Oct 30, 2005 | 06:37 AM
Default Re: (93h22a1vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">valve to piston, the valves were hittin on the edge of the notches</TD></TR></TABLE>
were the valves oversized or stock , or the piston relifs to small ,
reason i ask is i am getting crower 3 and i want to make sure im not goign to run into problems
Old Oct 30, 2005 | 09:01 AM
Isn't that because of camshaft timing?
Old Oct 30, 2005 | 09:06 AM
vinuneuro's Avatar
I remember reading on here that with the Stage 3's, Crower reccomends that you machine the rocker's to certain specs to prevent clearance issues. You should check with them. I'm almost positive that they reccomend this for the stage 3's.
Old Oct 30, 2005 | 01:19 PM
The_Head's Avatar
Default Re: (vinuneuro)
Yep its true I think it was .060" off the rockers.. We only did .030" might have to take em back to the machine shop again
Old Oct 30, 2005 | 03:18 PM
Fly1865's Avatar
Default Re: (The_Head)
I think machining the rockers is only if you use the spring/retainer kit.
From the Crower site:
Note: The Crower spring/retainer kit 84167 features a +.060" installed height retainer to allow more spring travel. This added installed height may interfere with the bottom of the rocker arms. If that occurs, you must machine the underside of the rocker arms for proper travel.
I think you can use the cams without the machine work, but if you use the valvetrain kit with thier cams you have to machine the rockers.
Old Nov 1, 2005 | 03:47 PM
Default Re: (Fly1865)
yes machining the rockers if when you have titanium retainers, and i did this. I did have oversized valves, but they weren't hitting JUST from that, it was a combo of things... .0015 off head, the cams, and who knows what else. But i do know that my timing was perfect, everything was at TDC before and after motor boom boom.
Old Nov 1, 2005 | 06:39 PM
The_Head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">i had crower 3s for 63 miles before my motor blew up due to clearance issues, but they were great. And i was usin stock usdm 10:1 pistons. Im using htem agian in my all motor build, but im goin with some weisco 11.5:1 (89mm big bore, hell yea).
I tryed IM'ing you... What was your VTEC crossover set at?
Old Nov 1, 2005 | 07:20 PM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">type s &lt; crower = skunk2 &lt; JUN
its all on hp basis....not preference...that ^^ will tell you what kinda power range youre looking at....</TD></TR></TABLE>
I want dynos. I made over 200whp and over 160wtq on a Dynojet 248C with Type-S cams, 11:1 compression and crappy 2.25" crush-bent exhaust... I make slightly more horsepower and torque than a friend's H22 with Crower 2's and 11:1CR and 2.5" mandrel-bent exhaust with comparable amounts of tuning. Do not underestimate type-S cams.
Pirate
Old Nov 1, 2005 | 07:26 PM
mgags7's Avatar
pirate, youre right...i should put type s cams in there with the others, but still below jun....
that h23vtec in the allmotor forum made like 250whp on a 248c with them...
but i have never seen a direct comparison like that before....do you guys have headers??
egb18c5
Mar 20, 2008 03:53 PM
espnews
Jan 4, 2008 09:02 AM
thestearninator
Jan 3, 2006 06:04 PM
vtec69
28
Apr 7, 2005 04:55 AM
Trbospnkr
Jul 16, 2003 04:53 PM
